Old 02-11-2013, 07:00 PM   #11
Stewart Way
Liked 70 Times in 22 Posts
Default Re: NHRA 2013 Rules Amendments
Think you are right. I remember collector extensions that were slip on but every collector I have had bolted on to 2 primary tubes. I see some stainless ones with spring attachments. Just too many words to say "collector". We know what they are saying but why not just say collector, not multi-piece exhaust collector? But Mr Tech Man, I don't need them because I have a 1 piece collector, not multi-piece. I was an NHRA tech man for years and this is what causes problems. Poorly worded rules or should I say wording open for arguement.
And are these really better-safer. Both do the job if they are secured but neither if they are not. I'm just being picky I guess.
Stewart Way 2424 SS
Old 02-12-2013, 10:56 AM   #12
SST159
Liked 20 Times in 16 Posts
So if your collectors and primary extentions are bolted to the primary tubes, are you still required to have this retention devise?
Drew Wonderly
SST 159
SST159 is offline   Reply With Quote
Old 02-12-2013, 11:04 AM   #13
JThomas
Liked 2 Times in 2 Posts
I remember someone losing a collector on a S/C dragster at the 90 race last year. Who was that?
JThomas is offline   Reply With Quote
Old 02-13-2013, 05:07 PM   #14
GaryGoFast
Talking Re: NHRA 2013 Rules Amendments
I guess a door car with headers bolted to collector to mufflers bolted to chassis isn't included in this rule. As the bolted in muffler would act as a restraint. But I wouldn't be surprised how NHRA interprets it.
Gary Federico
S/St, S/G 1814
GaryGoFast is offline   Reply With Quote
Old 02-13-2013, 07:13 PM   #15
Stewart Way
Gary
Don't be so sure. It says a removable collector must use an NHRA approved tether. Being bolted in doesn't make it non-removable. Your using logic again.
Stewart Way 2424 SS
Old 02-13-2013, 11:59 PM   #16
Bill Baer
I have lost one when the tab welds cracked
Old 02-14-2013, 08:04 AM   #17
1855sc
Liked 3 Times in 2 Posts
That lost collector at the .90 race was off of our car, and it cut the tire. If that matters. But, dont be fooled into thinking it cant happen to you. The rule is a good rule, but I didnt help write it.
Debbie Moses
1855sc is offline   Reply With Quote
Old 02-14-2013, 10:32 AM   #18
BKSG1198
BKSG1198's Avatar
I know it happened to Kenny at the .90 Nationals last year and also to Mike Holland on his burnout on his final License Pass on Friday Night at the .90's. They were able to kick it off the track before he backed up over it which would have made for a mess
Old 02-27-2013, 11:28 PM   #19
sg174crewm
Hey, I remember that. I think it is a good idea to tether the collector after what happened to me on my license run. I know most everyone goes over their cars with a fine tooth comb, but the collector tabs are something we never think will fail until it happens to us.
Mike Holland
SG/SC 1746
sg174crewm is offline   Reply With Quote
Old 02-28-2013, 11:07 AM   #20
SC321X
Looks like the only way to get around this rule is to WELD the collector to the tubes. So if I was building a new set of headers I would mount them on the car then weld the collector to the tubes before I powder coated them. That way they are not removable and don't need the teather. I have lost a collector on my old door car when the tab cracked. However on my Super comp dragster I have dynatec headers with 4 bolts on each header and they are out in the open where I can check them as I wipe them down after each pass. The old saying out of sight out of mind does seem to fit in some of the door car cases. I don't want to have to put up with the teather, so I guess I will have to weld on my chrome headers. We will see how the rules are applied. Any one else have any thoughts on the subject.
SC321X is offline   Reply With Quote
