Old 12-28-2012, 04:57 PM   #1
Jim Hanig
Liked 99 Times in 49 Posts
Default Stock/ss parts
1 402 BB 454 sleeved, lifter bushed, diamond honed 4.185 splay center caps. 1 375 402 cp pistons, crane cam, smith lifters,lifter bushed 454 sleeved blk 291 heads comp spring and lite retainers crane timming chain, comp timming cover,ati balancer, arp bolts,183 intake also have new 354 intake, msd dist, csr water pump, sheat metal valve covers,ls6 pan, low pressure pump.etc . 1 stock 183 intake . 1 bullet 390 410 stocker cam dyno time only. 1 18 degree edlbrock intake ported. 1 dart 23 intake gasket matched to 1206. 1set 041 heads stock 1 set o41 angle milled o to 80. 1 780 stocker carb PRC. 2 780 carbs 1 283 blk 1967 i think std bore. 1 50 mm super/stock cam 276/284. set small j rods new , 1 set 5.80 aluim rod small j ??. 1 set cp pistons super stock 1.5 1.5 3mm.small valve reliefs . 1 set 4.065 1/16 1/16 5/64 CA rings 1 lt1 stocker cam. 1 complete 283 ss motor old school 3500. never ran. 1set 4.130 ford pistons . PM me for prices if entrested. Jim Hanig
Old 12-28-2012, 07:18 PM   #2
jeff klei
Thumbs up Re: Stock/ss parts
P.M. sent. Thank you.
jeff klei is offline   Reply With Quote
