#61 |
That was GREAT, RallyeBob... learned all kinds of 8 cylinder words and everything !
HEEE HEEEE !!! Dave, Mikes car is a Super Stock... I think he has an aftermarket 4 link BTW, I got the ride height down, and did some measurements. It's better, but no where NEAR ideal.
Aubrey N Bruneau 6409 C/S 62 BelAir sport coupe, 409 HP 409 |
#62 |
I been thinking a lot about your 62 since I sent you a PM yesterday. I know guys that ran well in the day of these cars that did very little to the rear suspensions. Now I realize we have much better tires and a better clutch setup. These cars didn't seem to be so bad with a good set of tires and some shocks and maybe an airbag. It was soon realized that hard bushings and raising the mounting point of the top bar at the rear was the hot setup. Are you sure the front is working correctly. In the day everyone loosened up all the front end and the things nearly drug the rear bumper, but got weight transfer. Just some thoughts, I think you are getting there.
Jim N. |
#63 |
First, I'd like to thank everybody who advised me here...
I listened to all, and am applying what I am aloud to ! I must admit, I was just about ready to give up. Car has been jinxed ! EVERYTHING going wrong lately ! Have an engine miss that seems to be getting progressively worse. Concerned that it could be electrical system being over-taxed by the new "big" fuel pump, electric water pump and electric fan... with my stupid alternator not working. Seems to still be really lean too. Don't get THAT ? Same carbs I ran before. AS for traction, it appears that I may be getting there ! Raised the front about 3/4", and lowered rear a bit ( not enough yet ). On cold slicks, for the first time, I felt that "jump" effect of a drag car ! FINALLY got a hint of atmosphere under the front tires. I'm going to bring the rear down another inch. Car will still sit with some forward rake. thanks again, people Aubrey
#64 |
Glad you're finally getting some traction.
~Pete 1970 Nova |
#65 | |
Hope it helps.
http://home.earthlink.net/~whshope |
#66 |
Maybe ( likely ? ) I'm missing something, Billy ?
The diagrams helped though.
#67 |
Liked 511 Times in 122 Posts
questions aubrey...
what did you do with the 2 piece driveshaft ?? two upper links mounted at what position and hieght?? solid bushings all ?? rear locator bar used ?? fixed or floating ?? why was ballast bolted on rear crossmember frowned upon ?? spare tire & related fixtures used in trunk ?? rear bumper original ?? rear seat in place / factory ?? front bench seat / factory ?? what class does the wagon fit with the 409 4 speed ??? THAT would be a HOOT !!!! jack mccarthy usa3609@aol.com p.s. i get a couple inches of "atmosphere" in my u/sa wagon... but better weight distribution helps... 1790 / 2650 = 4470
Jack McCarthy 3609 STK "the Captain" Last edited by Jack McCarthy; 08-05-2007 at 01:11 PM. |
#68 | |
ALL the questions, Jack !
#69 |
Liked 3 Times in 1 Post
There is a guy in Atlanta that has been racing 60's Chevrolet's with 409 Plus Cubic Inch engines since day one. His Name is Lamar Walden, he is still Nostalgie racing those cars. I might can get his number if you'd like to call him!
Woodro Josey 2002 STK |
#70 |
Woodro...Could you elaborate on the approx date of Day one ???
