Old 07-17-2007, 09:58 AM   #1
Chuck Garey
Liked 10 Times in 7 Posts
Default Buick & LT-1/Pontiac parts
Will be cleaning out garage soon! Cars are sold so parts will go! Here's partial list:
2 bare 455 Buick blocks
.010/.020 buick crank
.030 over TRW flat top pistons (used) #H292NP
Lunati stage1 cam (used)
1971 stocker heads w/TA SS valves Poston springs $500
1971 Clean bare heads $200
Venolia stocker pistons (used) 4.375
Q-JET #7043242 modified air bleeds idle circuit $200
Q-JET #7041540 $50
.030 LT-1
coated Venolia's w/dykes ring set (new)
Eagle rods SCR-5700 BB
King accular bearings w/ARP bolts
Gm crank .010/.010
Roll Master double roller timing chain
Heads UP! prepped LT-1 heads never used #10128374
Unassenbled $3000.00
Heads #10207640 New never used stock valves and springs $400.00
.060 350 LT-1 w/94-275 Venolia's stock rods
.010/.010 GM Crank
Lunati stocker cam
Would make good street or bracket short block
$1000.00 OBO
ATI flex plate 153t used $40
TCI flexplate new in box #399773 168T $75
? New flexplate #3450231 153t $40
5.14 ring/pinion for 12 bolt $50 used
MSD HVC-2 coil for 7 series ignition $50
Speed Pro rings:
#R-9278 5 New $75
#R-10246 5 New $75
Crane springs #99846-16 $100
Misc gauges (Autometer) Tach, water, oil
Rimac bench spring tester $350
Mitutoyo #511 bore gauge $150
leak down tester
lots of other stuff I won'r be needing
SLP Ram Air hood for 98' up firebird (slight damage to corners but easy repair) never installed in primer.$450.00
Will try and take inventory and post prices after this weekend
Contact
Chuck Garey
Rgarey@chapusa.com
Last edited by Chuck Garey; 07-23-2007 at 10:27 AM. Reason: update info and pricing
Chuck Garey is offline   Reply With Quote
Old 07-23-2007, 11:23 AM   #2
Chuck Garey
Default Re: Buick & LT-1/Pontiac parts
Ttt
Old 07-25-2007, 03:50 PM   #3
Chuck Garey
Heads cannot be verified as heads up. Sorry
Old 08-21-2007, 01:15 PM   #4
Signman
Liked 269 Times in 99 Posts
Exclamation Re: Buick & LT-1/Pontiac parts
Sent you 2 e-mails
Am interested in the spring tester and some other tools you may have.
