Old 11-15-2012, 10:02 AM   #1
Liked 11,028 Times in 2,266 Posts
Default Aftermarket Cranks
Does this mean the FE Fords will loose the Chevy rod rod size? Or will the new cranks be turned from 2.437" to 2.200" before installation?
Ohio Crankshaft makes a cast iron (just like the real ones) 428 FE crank with stock mains and stock crank pins (2.437" just like the real ones) for about $500.
Old 11-15-2012, 12:15 PM   #2
Mike Crutchfield
Liked 4 Times in 2 Posts
Default Re: Aftermarket Cranks
Larry
The new rule only allows a aftermarket crankshaft with the same configuration as a stock one. The basic rule is the same as last year.
Hope this helps
Mike C
Mike Crutchfield is offline   Reply With Quote
Old 11-15-2012, 12:24 PM   #3
Todd Hoven
Guest
Posts: n/a
It's the rod that is approved to use that size journal , has nothing to do with the cranks.
Old 11-15-2012, 01:10 PM   #4
Tom Moock
Liked 10 Times in 6 Posts
Mike, were is the list of approved crankshafts? Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 11-15-2012, 01:36 PM   #5
69Cobra
Liked 2 Times in 2 Posts
Bingo!
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 11-15-2012, 04:17 PM   #6
SSDiv6
Here we go again!!!
Hold on and let me grab the Popcorn!!!
Old 11-15-2012, 06:55 PM   #7
Terry Cain
Terry Cain's Avatar
Liked 232 Times in 108 Posts
Originally Posted by 69Cobra View Post
Bingo!
Don't cha just lov em?
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 11-17-2012, 09:01 AM   #8
Rusty2211
Talking Re: Aftermarket Cranks
Larry,
I think the time has come for you to build a CJ. With the new aluminum police interceptor intake that's legal, the big 780 quick fuel carb, high port edelbrock heads and the 525 cheater cam, this thing should be able to run 9.50's in B/SA. The chevy rods are a bonus too and you should be able to spin it up to 8500. The aftermarket crank rule helps. I'm trying to the the honda rod approved for the FE and working with Wineberg on a new 41 lb crank. Should work well.
Rusty
Rusty2211 is offline   Reply With Quote
Old 11-17-2012, 10:07 AM   #9
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Originally Posted by Rusty2211 View Post
Larry,
Rusty
By the reaction of some people, the newly approved factory replacement parts for the AMCs is heresy, but the cancer of "parts creep" is everywhere.
Old 11-17-2012, 10:37 AM   #10
Todd if the cranks can only be turned to -.070 under OEM size, the "length custom" rod with housing bore of 2.325'' would have to be installed with a four pound hammer. It would be my quess that unless great care was taken during assembly the assembler would would collaps the top and second ring land before the bolts and cap would be close enough to be tightened. Once tightened the broaching process of the crankshaft will be compleated.
Rusty the .525/.525 cam is the 427 one or two four barrel you know 410 and 425 hp. The "cheater cam", your words not mine, is .527/.527, it can check .525/ .525.
After some thought I believe the engine stand or the snout of the crank would break before all eight piston and rods were in place and torqued.
