Old 10-07-2012, 04:51 PM   #1
H.A.A.C. Racing
H.A.A.C. Racing's Avatar
Default E85
Anyone useing it? Pros, Cons? Who deos the best conversion?
H.A.A.C. Racing is offline   Reply With Quote
Old 10-07-2012, 06:33 PM   #2
T Hall
T Hall's Avatar
Default Re: E85
I switched my big block nova over early this season. It didnt go any faster or slower, stayed the same, consisncy is good, but it allways was good. I bought a whole drum of fuel at $2.81 a gallon though. So I am glad I made the switch. I put a quick fuels e85 kit in mine. Have $300 in, it. well worth it. I have heard that Shipps run it in their cars also, and they are obviously pretty sucessful.
I have heard that its not very good with 13.1 or more compression. Yellowbullet.com has a huge thread about it, many people run it and all love it. Go for it
Tony Hall
3545 S/ST
T Hall is offline   Reply With Quote
Old 10-07-2012, 06:50 PM   #3
billy leber
Liked 10 Times in 1 Post
Default Re: E85
I run it with 16 : 1 with no problems .
Billy Leber 1150 SS, 1050 SG, 1962 STK, 185 SC
billy leber is offline   Reply With Quote
Old 10-07-2012, 07:04 PM   #4
T Hall
T Hall's Avatar
Default Re: E85
Billy, how much fuel pressure do you use?
Tony Hall
3545 S/ST
Old 10-07-2012, 11:48 PM   #5
billy leber
Default Re: E85
Same as I used for gas , as much as I can without it dripping . Its usually fine at 9 psi . Also I used the same kit as you did , Quick Fuel .
Old 10-08-2012, 12:26 PM   #6
T Hall
T Hall's Avatar
Default Re: E85
I may be using to little. I am at 7psi
Tony Hall
3545 S/ST
Old 10-08-2012, 12:31 PM   #7
H.A.A.C. Racing
Default Re: E85
so no mods need to be done with the main body besides what they give you in the kit? If I run 92 jets squared, what should I start with on E85? How is it on the throttle stop?
Old 10-08-2012, 02:02 PM   #8
sg1586
Default Re: E85
Been running E85 for a wile and did my own carb. Be careful with the QF kits as the metering blocks do not have a main well that big enough for a large motor..
With my 540 I have picked up almost .07 and 2 mph and cut my short times by .02...
I was running 94 jets with gas and now running 164 alky jets with E85.
There is more than just throwing the QF kit at it and seems that it likes less emulsion and smaller holes and also it works better with a 2 circuit carb conversion IMO...
Spark plugs are hard to read so be careful.. Price and the cooling effect is all a plus as in the heat of the summer here in NJ I would have 200+* after a run and a extended cool down time now it rarely gets above 190*..This is a plug with a lot of runs on it..
sg1586 is offline   Reply With Quote
Old 10-08-2012, 07:19 PM   #9
billy leber
Default Re: E85
Wow ! I ran 94 jets with gas and run 102 with E-85 . I just bolted the Quick Fuel kit on and was happy with the results . Every car I have done it to has picked up at least a tenth in the eighth mile over gasoline. I run it in a 632 and a 555 .
Old 10-08-2012, 08:39 PM   #10
Tom Goldman
Tom Goldman's Avatar
Liked 885 Times in 238 Posts
Default Re: E85
Billy, did you change the cam at all when switching to E-85 ?
Tom Goldman is online now   Reply With Quote
