Old 09-12-2012, 10:23 PM   #1
Stephen & Horace Johnson
Liked 166 Times in 54 Posts
Default No AFHS for National Open @gainsville
Let's see who really really lets it all hang out and takes all the weight out of there cars...
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is online now   Reply With Quote
Old 09-12-2012, 10:54 PM   #2
boostedf22c
boostedf22c's Avatar
Default Re: No AFHS for National Open @gainsville
Are they running class at this event? Record runs?
Carey Bales
316D DD/AT
www.racetactics.net
boostedf22c is offline   Reply With Quote
Old 09-12-2012, 11:17 PM   #3
no class RO's. Nat opens are where the RACERS set records! this has been an on goin thing for a while about setting records or running fast as you can in class and not getting hit with HP....
There will be alot of them taking the block of wood from behind the pedal this go around..
Old 09-13-2012, 12:45 AM   #4
Tom Moock
Liked 10 Times in 6 Posts
Stephen, at National opens if go more than 1.20 under you get Hp. but runs don`t count on your average`s. Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 09-13-2012, 12:49 AM   #5
tom , the reason why i made this post is because i got an email that the AFHS is not goin to count for this race..it was voted not to count against ya!!!!!!!!
Old 09-13-2012, 01:20 AM   #6
Tom Moock
Stephen, sounds like a combo race not a NHRA Open with record runs.Tom
Tom Moock 5704 STK
Old 09-13-2012, 01:35 AM   #7
art leong
It is a national open with record runs. I believe there will be no normal AHFS but if you go more than 1.199 under you will get the instant hit. Whether you set a record or not.
Art Leong 2095 SS
Old 09-13-2012, 03:22 AM   #8
RULER
Liked 58 Times in 18 Posts
Wink Re: No AFHS for National Open @gainsville
No vote nessary, that is the way all national opens are run, no HP unless you go 1.20 under then you get the instant hit on monday or tuesday the next week! some combo's still need that block of wood under the pedal
RULER is offline   Reply With Quote
Old 09-13-2012, 07:30 AM   #9
Chad Rhodes
Those of us that got the email from Mike Crutchfield........ It says NO AHFS, none zip, nada, take the lead out and and bomb the record 1.20 under be damned.
Chad Rhodes 2113 I/SA
Old 09-13-2012, 09:22 AM   #10
Bruce Noland
Liked 444 Times in 145 Posts
They may be saying the ahfs is not in play, but I would be very surprised if they will let a -1.20 run slide.
Bruce Noland 1788 STK
