Old 08-21-2012, 02:01 PM   #31
Chuck Beach
Chuck Beach's Avatar
Liked 58 Times in 13 Posts
Send a message via AIM to Chuck Beach
Default Re: NHRA Changes the Rules Today
Originally Posted by A56 View Post
Before I spend 30 minutes of my time, does anyone know off the top of there head what classes the 360 DPs can run and what class the 352 Mustangs can run and what about the 302 Coyote Mustang ?
Mark Lelchook
F/SA #764
Mark, the 360 DP is at 310 HP with a break of 10.32 ... D, E & F
The 352 Stang is at 312 with a break of 10.43 ... D, E & F
The 302 is at 325 with a break of 9.91
Chuck Beach
3340 STK
Chuck Beach is offline   Reply With Quote
Old 08-21-2012, 02:14 PM   #32
Chuck Beach
So the Coyote is a C/ D / E car then, is Joe Teuton incorrect then about the natural class of the 360 DP, I see it as a natural E car not F ?
Thanks
Mark Lelchook
F/SA #764
That is correct ... your 69 breaks at 10.47 with is a natural E car, my 68 breaks at 10.58 which is a natural F car .. but you already knew that ..
Chuck Beach
3340 STK
Old 08-21-2012, 02:18 PM   #33
Joseph Teuton
Joseph Teuton's Avatar
Originally Posted by a56 View Post
so the coyote is a c/ d / e car then, is joe teuton incorrect then about the natural class of the 360 dp, i see it as a natural e car not f ?
Thanks
mark lelchook
f/sa #764
yes i forgot that the last hp hit took us out of g/sa. So we are an e/sa car now but we can barely get to max weight for e/sa plus there is already a dp in e/sa. With a 6'4" 280lb driver we cant get to d/sa. Lol
JOSEPH TEUTON
4044 STK,SS,
Joseph Teuton is offline   Reply With Quote
Old 08-21-2012, 02:25 PM   #34
jmcarter
jmcarter's Avatar
Liked 3,235 Times in 984 Posts
Originally Posted by Jeff Teuton View Post
Typing error being corrected to reflect 3475 for V10. Thanks
Well, at least that sounds somewhat more equal but what about the .400 tree out of the blue? Seems like unfair advantage for the 3 speed cars...plus the FS/S cars will run class using a pro tree and then eliminator using a full tree? I would claim foul on that one even if I had a trans brake and 3 speed...
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 08-21-2012, 03:08 PM   #35
Andrew Hill
Andrew Hill's Avatar
Liked 174 Times in 39 Posts
Mark you probably feel like I did with my 69 6-Pak everytime I rolled up against a 396. I got no help or sympathy from anyone.
That's like comparing a small hill with Mt. Everest.
That is why I proposed a 5% reduction for all older than 2008. Easy to do on Excel from what people with a higher grade level tell me.
Why reduce the HP on 95% of the cars instead of raising the other 5%?
3207 D/SA, C/ED
Andrew Hill is offline   Reply With Quote
Old 08-21-2012, 03:23 PM   #36
Ed Wright
Ed Wright's Avatar
Makes too much sense.
Ed Wright 4156 SS/JA
Old 08-21-2012, 03:33 PM   #37
Joseph Teuton
Why reduce the HP on 95% of the cars instead of raising the other 5%?[/QUOTE]
Because the 95% are the ones complaining. So fix the ones that complaing. =) Plus it's all done by excel so it's just as easy to do 95% as it is to do the 5%.
Just like we are not asking to take away the three speeds from the CJ's and COPO's, we are asking to give us one!
JOSEPH TEUTON
4044 STK,SS,
Old 08-21-2012, 04:03 PM   #38
Jeff Teuton
Liked 325 Times in 50 Posts
Your on-the-scene reporter has unraveled the problem. First it's fixed, Thanks NHRA. On May 9, a proposal for the Shootout was done and sent to the manufactureres. The weight was 3575, which was too much. After discussions, it was reduced to 3475 and posted on the tech site on June 18. When the adddition of the pro tree and a couple of other things were done, the weights from May 9 were picked up instead of June 18. Mystery solved. My blood pressure has now returned. Perhaps I overacted a bit, but I am pleased to announce it was handled poste haste (thats right now for you non-belivers). Now as far as the other age old discussions on here, they are like crabgrass, just won't go away. Next year we (and anyone else) have the three speed, so that is good. I had a good discussion with Glen Gray and Bruce Bachelder of NHRA as well as numerous e-mails with Pat in California. I ruffled some feathers for which I apologize. Maybe I was too involved in trying to get 5 cars to BG and Indy, and get over the martinis I was having when my son called and said we got 100 lbs added. The problem is fixed and the communication lines are wide open. Thanks.
Jeff Teuton 4022 STK
Old 08-21-2012, 04:21 PM   #39
Dyno
Dyno's Avatar
Liked 695 Times in 206 Posts
Hopkins ran in C/SA with his 13 Mustang/5.0 at BIR
Old 08-21-2012, 04:26 PM   #40
Brett C
Liked 1,074 Times in 227 Posts
Good news for the Mopar camp! Maybe they'll get off the porch and play with the big dogs now???
Still disagree with the pro tree thing though. Makes no sense at all. How are they going to qualify? Run with the stockers on .5 full tree, then you have to run a .4 full tree for the class, then revert back to .5 full tree for eliminations? Total nonsense! Way overthought!
Anyway, see you guys there!
Brett Candies
4192 Stock/SS
