Old 05-14-2012, 07:20 PM   #1
7sec.cuda
Default Tire pressure gauge
what are some of the more accurate ones out there? what is everbody using thanks
7sec.cuda is offline   Reply With Quote
Old 05-14-2012, 10:56 PM   #2
Geerhead55
Liked 5 Times in 5 Posts
Wink Re: Tire pressure gauge
I've been using my trusty 'ol Moroso gauge for quite a while now,,, no problems,, just make sure you get the protective rubber sleeve, in case it gets dropped.
Once you get something, stick with it for consistency, instead of borrowing from this guy or that guy, using different gauges.
I have mine specifically for the slicks and I have one strictly for my frontrunners.
Surprisingly,, I got a digital, illuminated, gauge for my birthday recently which reads fairly close to my regular gauges. Since I know this is a cheaper gauge, I haven't put a lot of trust in it, but its in my "track box", for a backup if its needed.
Good luck with your search.
Danny Durham
Old 05-15-2012, 08:40 PM   #3
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: Tire pressure gauge
Been using a Jeg's digital that I'm very happy with. Reads to the 1/10 of a pound. I think it's about $90. Jim
Old 05-23-2012, 08:05 AM   #4
Phil3700
Default Re: Tire pressure gauge
Intensity racing products has a nice gauge called pressure inc. Works good!
Phil3700 is offline   Reply With Quote
Old 05-23-2012, 08:47 AM   #5
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
If you already bought a gauge with the bleed fitting, then all you need to do is visit a Grainger to get a quality replacement gauge. You could also get a glycerin filled gauge. But it requires more time to deal with, as the ambient temperature affects it. It requires you to open a vent to equalize the pressure on the bourdon tube. The advantage to the glycerine is durability. You can get a large diameter segmented gauge too.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 05-30-2012, 01:11 PM   #6
bobby
bobby's Avatar
Danny Durham
I'm with this guy. I have 2 Moroso guages and they are with in 1/8 of a pound of each other. One for each car.
Next time wave all of your fingers at me.
bobby is offline   Reply With Quote
