Old 04-17-2012, 11:26 AM   #1
Tmarlow4228
Default Need help with my launch RPMs on a 500 pro tree
I just started running super street and the car likes leaving at 4600 with no numbers in the box. When I hit the trans brake and deck throttle the car holds at 4200 before going to 4600. Which cause me to have inconsistent re action times. I just switched to a e85 carb. Any advice??
Tmarlow4228 is offline   Reply With Quote
Old 04-17-2012, 11:45 AM   #2
C and W Racing
C and W Racing's Avatar
Liked 13 Times in 3 Posts
Default Re: Need help with my launch RPMs on a 500 pro tree
I would tend to think that if you have a sprag in the converter, it is starting to go away. Either way, I would look at the converter.
Chuck
C and W Racing is offline   Reply With Quote
Old 04-17-2012, 12:12 PM   #3
Tmarlow4228
The cars still consistent in 60ft and mph
Old 04-17-2012, 02:44 PM   #4
HR9121
HR9121's Avatar
Like Chuck said look at the converter, had a similar problem with sprags now a spragless by Ultimate so far so good.
James Williamson
W200 J/SA. SS/JA
Old 04-17-2012, 02:46 PM   #5
hookdaddy
Liked 8 Times in 3 Posts
put a launch rpm chip in it instead of leaving "on the wood" Your on the wood rpm can be effected by slight changes in weather. Try putting a 4400 chip in it. That way you know you be leaving at the same rpm everytime.
Don Scholl
d.scholl@comcast.net
145Y Stock - 145H Super Comp
hookdaddy is offline   Reply With Quote
Old 04-17-2012, 04:43 PM   #6
HR9121
HR9121's Avatar
My bad I guess I didn't read it very well I assumed he was leaving on a chip.
James Williamson
W200 J/SA. SS/JA
