Old 03-19-2012, 07:13 AM   #1
Ian Hill
Ian Hill's Avatar
Liked 6 Times in 3 Posts
Default How often do you re-silicon your trailer roof?
Is it a common preventative maintenance for trailer roofs to have to be re-siliconed every few years?
thanks
Ian
Ian Hill is offline   Reply With Quote
Old 03-19-2012, 09:31 AM   #2
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Default Re: How often do you re-silicon your trailer roof?
Ian,
What length of trailer and what brand? TAG, GN?
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 03-19-2012, 12:41 PM   #3
jim powers
jim powers's Avatar
Liked 13 Times in 10 Posts
i have a 6 year old vintage and i redid a few spots last year,not the whole roof, mostly the rear corners
jim powers is offline   Reply With Quote
Old 03-19-2012, 12:49 PM   #4
Phillip marvetz
Phillip marvetz's Avatar
I did my very old 44gn 4 years ago and it still looks fine.
2009 V/SA Record Holder
Old 03-19-2012, 01:59 PM   #5
njk53
Do you guys out there recommend a specific brand of silicon material? If so what is the cost and how do you prep and apply the stuff. Our 35' goose neck is going to be due for a re-seal.
Nelson Kowal
Stock 345
Old 03-19-2012, 10:34 PM   #6
Phillip marvetz
I'm not sure if it was right or not but I bought some clear silicone down at the hardware store,, Ruffed up the old stuff with a wire brush and layed down a new bead. The trailer come out of L.A so the old stuff was really dried up.
Old 03-20-2012, 02:56 PM   #7
Ian Hill
Ian Hill's Avatar
i have an MTI - 32 foot. brand new late last fall. it has a small leak, i will be repairing soon. i was just making a plan of maintenance more or less.
Ian
Old 03-20-2012, 08:27 PM   #8
RacingRicki
Sponsor
RacingRicki's Avatar
I have had to reseal different trailers of mine. I used some kind of RV roof sealer but it didn't seem to hold up very well. It would get hard and crack.
Since then I found something better. Its called BondaFlex Sil 199 PG. You can use a regular caulking gun to apply it then spread it out with a putty knife. To prep the surface I used denatured alcohol on a rag. So far I am happy with the results.
I got some directly from the Vintage parts department. Search the Internet. I'll bet you can find a place to buy it or just call Vintage.
RacingRicki
RacingRicki is offline   Reply With Quote
