Old 02-24-2012, 10:09 AM   #11
Lyn Smith
Liked 1,001 Times in 203 Posts
Default Re: Removing Decals
Wax and Grease remover works best for removing the glue.
Old 02-24-2012, 10:53 AM   #12
Ron Ortiz
Ron Ortiz's Avatar
Liked 317 Times in 103 Posts
A more fun way of removing decals is with your fingernails. If after repeated attempts, and a few beverages, they don't come off, it is easier to just buy another car. Another tip form beyond common sense.
Ron Ortiz
U/SA goo gone
Ron Ortiz 2102 STK
Ron Ortiz is offline   Reply With Quote
Old 02-24-2012, 10:54 AM   #13
Rob Petrie E395
Liked 216 Times in 77 Posts
Napa sells the plastic razor blades and they work great along with a little heat.
Old 02-24-2012, 11:32 AM   #14
Ed Wright
Ed Wright's Avatar
I use a heat gun, and I don't pull up on them. They seem more prone to come apart that way. Fold them over and pull straight back on them has worked best for me. Taking several off mine this weekend.
I usually take the glue off with a shop towel damp with Safety Kleen parts washing solvent, and WD40 works pretty well. Not as fast but does work.
Ed Wright 4156 SS/JA
Old 02-24-2012, 11:50 AM   #15
Angelo DiTocco
Angelo DiTocco's Avatar
Liked 189 Times in 48 Posts
Ron Ortiz
U/SA goo gone
Ron - as sad as it sounds... that's how I've been trying to do it -
Thanks to all for the tips - gonna give it another try today
Angelo DiTocco
'98 Firebird SS/HA
'98 Firebird B/SA
Angelo DiTocco is offline   Reply With Quote
Old 02-24-2012, 03:20 PM   #16
George Fitzpatrick
George Fitzpatrick's Avatar
Liked 94 Times in 24 Posts
Hair dryer or heat gun. Just finished taking them off the Cuda. Painfully long, just put some tunes on and take your time. Tar and bug remover works ok for excess glue.
George Fitzpatrick 426 HEMI STK, SS
George Fitzpatrick is offline   Reply With Quote
Old 02-24-2012, 03:59 PM   #17
PATIENCE and any of the above methods combined in any form.
Oh, and PATIENCE!!!!!!!
Gasoline will cut glue as well as any of the other methods mentioned.
Old 02-24-2012, 05:05 PM   #18
63corvette
Liked 362 Times in 105 Posts
I was told to try Easy Off Oven cleaner and I was a little afraid of the paint on the car being damaged.
However, I tried it and it works pretty well. You must rubber gloves but it did not damage the paint at all.
It is also much easier and faster than WD-40.
You will need a good supply of soft rags or soft shop paper towels.
I used it and it works.
My 2 Cents
Rick Cates
63corvette is offline   Reply With Quote
Old 02-24-2012, 06:13 PM   #19
tim worner
Liked 126 Times in 20 Posts
The hair dryer then a coat of Goo Gone from Magic American Products,Bedford Heights,Oh. Then plenty of elbow grease. Seems to be more comming off of cars than going on these days. That trick of getting clothing lint on the sticky side of the new decal does work well.
Tim Worner SS 1747
tim worner is offline   Reply With Quote
Old 02-24-2012, 06:27 PM   #20
Joey Bohannon
Liked 61 Times in 22 Posts
I would use a hair dryer before the heat gun, you can bubble paint with a heat gun with no problem at all. A hair dryer is without a doubt your safest bet. I use regular gasoline for glue removal and have done it on hundreds of cars over the years. If you have static electricity issues in your area use the wd40, but be prepared to be patient. I have never had an issue with using the gas but I am also very cautious when using it. It will not hurt your paint......least it never has hurt anything i've used it on.
Joe Bohannon
A Plus Signs and Screen Printing
502-797-1352
Joey Bohannon is offline   Reply With Quote
