Liked 2 Times in 1 Post
Does anyone have a Wilwood brake pad recommnendation for a Super Gas car? Wilwood suggests "B" pads or "E" pads depending on who you talk to. Strange reccomends a softer pad in front with a propotioning valve but does not know much about Wilwwod specs.
I just do not want to have any supprises the first time I run it full out. Weight 2400# anticipated MPH 160-165 Thanks in advance |
Liked 887 Times in 239 Posts
I've had the best results with the Wilwood polymatrex B on the rear brakes ,and Polymatrex E on the front. ...Both last about 80-100 runs neutraling and shutting off the car
My car weighs 2300# and runs mid 160's I have a limiter valve on the front brakes to slow the initial hit mainly for tracks that dont have much spray on them since the weight bias is 54% on the rear. There are a lot of variables involving pads, pedal ratio,pressure ,track condition & temp,weight and speed.[ and wether you want to make the car dissapear at the finish line!!]
#3 | |
I also use the B's on the rear and the E's on the front I change em 2 times a year as well as replacing the fluid. My Proportioning Valve is set at 65% to the rear.
Chuck Westcott- S/C -S/G 225 |
Liked 37 Times in 33 Posts
Tom,
Are you running the small (3") caliber's on the front with the disc type pad from Wilwood? Thank's. |
I always ran the gator pad on my vette roadster front and rear. It will stop so you have to get use to them.
BB |
#6 | |
Barney, those Gator pads are the best pad I tried for a heavy car,I have them on my Willys,but they were way too agressive for the Vette. I didnt think they were available anymore.
Tom,
Thank's for the info. Appreciate it. I think I have the same set-up on the front as you. |
Tom, I just seen gator pads listed at Summit Racing so they must still make them.
http://www.summitracing.com/parts/WIL-150-2391K/ BB |
