1992 Super Mod. Camaro
currently running SS/BS.... many time record holder, car is set up for stick or automatic, V8 or V6, two hoods, two sets of headers, MW alm. driveshaft, two sets wheelie bar struts, 3 motor plates, Racepak SC 1000 computer, Koni elc. shocks, Lamb brakes and struts, weld wheels, goodyear tires, turbostart, magnafuel, ALL THE GOOD STUFF.... VERY FAST AND WELL KEPT CAR!!!! NOT beat up!! Everything but engine and trans. $22,000 OBO I can also set it up to run SS with a Fresh 311 SBC and a 2 speed glide... 311" SBC 13* Chevy bowtie block 8.800 deck hight HRD 615x heads HOGANS intake single and dual four tops CROWER crank BULLET cam CP pistons GRP rods STEFFS oil pan PETERSON wet/vac. pump PRC 750 carb. JESEL rockers, pushrods, and belt drive MEZIER water pump 13,500 OBO MUST GO!!! HRE intake for CFE 10* heads, Block was 8.800 comes with two tops.... only used ONE season!!! LIKE NEW $1100 OBO 1- Lakewood 8 1/8 steel can, fork @ 9 o clock, Chevy bolt pattern $700 1- Set GoodYear 1999 98" roll out 20 runs $100 1- 461X chevrolet head (ONE ONLY) $make offer 6. MGP rods 1.888X5.840 new hard bore finish with .929X2.500 Pins $650 1. A1 7'" converter AE300-8 $500- 1. BBC Jesel belt drive (missing cam hub) $400- 16. PAK ***. retainers 1.500 dual springs $200- 8.PPC 2.250 x.927 coated wrist pins $350- 6. *** coated wrist pins .927x 2.500 $300- 6. Jesel splayed valve intake rockers DA2D75 $300- 16. PAK 1355 springs $100- 8. Crower.842 roller lifters 15*(40 runs) $50- 16. Xceldyne super 7* ***. retainers and 5/16 ***. locks $250- 8. Jesel 15* exhaust rockers DHEL65 $400- 8. Jesel 15* rockers CJBL70 & CUGR70 w/ shafts $800- 1. 9" ford iron case with 3.250 bearing $175- 9. CP pistons 4.150x1.375 blob domes $400 1. Penske shocks reg. and air release valve (test only) $150- MISC. 50 & 55 MM Roller cams $150-$300 (CALL) JESEL push rods 8. dbl. taper .400 to .440 x 9.040 ball end 8. dbl. taper .500 to .560 x 9.020 ball end 16. dbl. taper .400 to 440 x 9.120 ball end MANTON push rods 8. single taper .380 to .440 x 8.870 cup end 8. single taper .380 to .440 X 9.050 ball end ALL PUSH RODS $15 EACH All buyers pay for shipping.... ALL PRICES ARE WORKABLE CALL JOE CARNASCIALE FOR MORE INFO... 401 447 4650 401 943 6029 |
Liked 4 Times in 4 Posts
i am interested in the 9" ford case. is it still for sale and what make and model is it ? thanks ron b
