Liked 53 Times in 24 Posts
I AM LOOKING FOR A GOOD LIGHT WEIGHT BATTERY THAT HAS ENOUGH RESERVE TO GO A FEW ROUNDS OR RECHARGES FAST BETWEEN ROUNDS
Rock battery
Liked 54 Times in 33 Posts
Kip? Where d'ya get a "Rock" ?
I miss step. |
I got mine from Les Figueroa at the track. It works great.
12 or 16 volt ?
I miss step. |
Guest
Posts: n/a
Here's my cheap lite-weight solution. They make a special size (I forgot the group number) for Honda Civics. Tell them you have a 1992 Civic. No more than $58.00 depending if you get the standard or premium model. Buy two. Charge both the night before. Use one for qualifying then change it out for eliminations. You can charge the 1st battery and if you make it to the 4th round, rotate the battery. Besides being cheap, they weigh only 15 pounds each. I never had one problem in Stock with my 390 engine and constantly forgetting to turn the water pump or fan off while in the pits.
NHRA #7494 SS/H 1970 AMC AMX "Best Appearing" @ NHRA '06 Pacific Sports Nationals JeffLeeAzRealty@Qwest.net 602-418-9797 |
There is a battery company in the Phoenix area that has every type of battery produced. I looked at the ones used in NASCAR. Very light and must work well.
Liked 1,958 Times in 593 Posts
I did the same as Jeff Lee. Went t o Walmart and found a small battery with 650 CCA weighs about 28 lbs. costs about $50.00. Saved about 30 lbs over th group 27 battery.With a full charge and a retard control on the MSD I have no problem starting my 350/ 295 super stock camaro even when going round robin in eliminations
Mike Pearson 2485 SS |
Odyssey has a small battery that is about the size of maybe a cross between a lawn tractor battery and a motorcycle battery,plenty of reserve and CCA.Summit has them for about $130.
Nautilus Racing
Nautilus Racing |
Liked 29 Times in 6 Posts
The Odessey batteries are a really good battery to go with. They are a completly dry battery and they have tons of power. They weigh a bit less than the Optima battery but have more power.
