Liked 15 Times in 11 Posts
Small block Chevy stocker engine, is there any advantage to using a1 3/4 to 17/8 inch step header over the smaller 1 5/8 to 1 3/4 inch step?
Liked 539 Times in 112 Posts
Probably going to need more information. Displacement? Carbureted or EFI? Compression ratio? RPM range? Car type & weight, etc., etc., etc.,
Jim Kaekel 3836 STK |
Liked 1,952 Times in 439 Posts
That would be a question for PipeMax software, Jere Stahl, or Calvin Elston (who will tell you that you need 4-2-1 or tri-y headers). I'd need a detailed sheet on the engine to give you a good idea what it wants.
Alan Roehrich 212A G/S |
The engine is .040 over 350, 10.5 comp. 750 dbl pump on victor jr, car weight 3100. running in IHRA Crate Motor class. Trap RPM 7200. I have always thought the pipe at head should be approx. the same size as exhaust valve but have gotten some opinions that the larger 1 3/4 inch pipe at head works better. The 4-2-1 collector is pricey but have heard well worth the investment. Thanks for your input gentleman.
Liked 279 Times in 68 Posts
That motor is comparable to the motor in my car and my stahl headers are1 3/4 to 1 7/8 with a 3" collector. With a tri Y it's a whole different deal.
Greg Hill 4171 STK |
Liked 5 Times in 3 Posts
Dave I have had the 4-2-1 collectors & Merge both on my car......Same E.T. out of both. I would go with the 1 5/8 step to 1 3/4........unless your running the Fast Burn heads.
Liked 462 Times in 92 Posts
1 5/8...............
Bob Bender 144 O/SA 2010-2012 National Record Holder |
Liked 138 Times in 51 Posts
Several IHRA and NHRA 360 Stockers, including myself, use off the shelf TTI 1 5/8"-1 3/4" step headers with good results. But they only manufacture Mopar applications.
Liked 20 Times in 3 Posts
Whatever Greg Hill is running.
Liked 3 Times in 1 Post
Either size will work well on a 350. Don't fall into the "equal length" trap. Just buy a merge collector from Performance Welding. The larger header may want to be shorter on the primaries. If you don't buy a merge collector, consider buying or building a header that fires in rotation into the old style collector. But, the bottom line is, it's all theory until you get an ET slip........
Wade O |
