Old 09-07-2011, 08:05 PM   #1
cwoodW252
Default Converting a 68 camaro to a stocker
I have a 68 camaro that is tubed with leaf springs and ladder bars and am considering changing it back so I can run it in stock. Has anyone had any experience with doing this. Wondering how hard it will be. Also what are some recommendations in running a 350 combination?
Thanks Chris
cwoodW252 is offline   Reply With Quote
Old 09-07-2011, 08:19 PM   #2
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
Default Re: Converting a 68 camaro to a stocker
If the factory frame rails are still there it shouldnt be a problem. They sell all the trunk/wheelhouse/shock bracket mounts to put it all back....just cut and paste like nothing ever happened. My camaro had some goofy shock brackets when I got it and I bought all the pieces to fix it and make it look stock again.
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 09-07-2011, 08:27 PM   #3
Liked 1,912 Times in 429 Posts
Dan Fletcher's stocker was once a Super Stock style car.
You'll have to cut the entire floor pan out where it was modified, and return it to stock, you'll have to remove the ladder bar cross member as well. It's a ton of work.
You might be better off to find another car.
There's only one 350 for a 68 Camaro, the 295 horse version, rated at 290 in Stock. If I were going to run that combination, I'd run it with a 4 speed.
Old 09-07-2011, 08:36 PM   #4
Jeff Lee
Jeff Lee's Avatar
Who's that company...Detroit Speed...sells those Camaro larger than stock but stock appearing wheel houses...
Jeff Lee 7494 D/S '70 AMX
