Old 08-19-2011, 04:32 PM   #1
ssam4104
Default billet aluminum intakes
f/s billet aluminum intakes 1- sbf set up for SC-1 heads 8.2 deck . set up 2-4150s with spacers .1 for 9.2 deck set up for yates heads with 2-4150s also with spacers both are new. Have pics send email address to mddd4104@aol.com or call Don Bevers @520 -631 -1587 or Candy Mesa 915 479 -1035. can make any intake for your application be it ford mopar chevy or imports. turbo injected blower etc. We can help you .We can offer our services to help you get optimal performance out of the intake. we run SS/AM /SSBM we have dyno tested our stuff.We have made intakes to fit under superstock hoods thanks
ssam4104 is offline   Reply With Quote
Old 08-20-2011, 10:28 PM   #2
brobaey
Default Re: billet aluminum intakes
Any pictures of the billet 8.2 setup for SC-1 heads? Will this work with a set of Yates C3's? Also, if not how much for one that fits a yates heads 8.2 deck motor.
This will be going on a F1R blower setup.
brobaey is offline   Reply With Quote
Old 08-20-2011, 11:20 PM   #3
ssam4104
if i understand what your needing is a manifold for a procharger with a throttle body and injected . we can do that with 2 injectors boses per runner.and a throttle body plate 105mm or what your planning on running.. we can build a piece like that for about $3000.00 if you want call me at 520 631 1587 cell ..arizona time Don Bevers.... to answer your question the ports are custom spacing between the sc1 and the yates close but no cigar. send me your email address to mddd4104@aol.com and i send you some pics of our manifolds thanks
