Old 07-12-2011, 11:12 AM   #31
goinbroke2
Liked 383 Times in 149 Posts
Default Re: Track is making up rules
And I fully agree with that. However, if you would of slowed down enough not to raise eyebrows and be able to dial inside the class, there would be no issue.
In other words, if your running a 10 sec car and slow it to 13:00 and dial it 13:00 there is no issue. And if your running 13:00 at 110mph..well your the same as a new stock 5.0 mustang with a good top end charge. (and no I don't agree with a 13:00 170mph car running 13:00 97mph cars)
Old 07-12-2011, 03:43 PM   #32
larry dowty
Liked 11 Times in 4 Posts
DON i get it i just dont think you should be able to go faster than 12.00 in sportsman PERIOD
larry dowty 6388 SS
larry dowty is offline   Reply With Quote
Old 07-12-2011, 04:04 PM   #33
novassdude
Liked 136 Times in 49 Posts
I am confused about the rule they claim to be following. In the Super classes you are not DQ'ed for going under the .90 are they saying if a 9.90 car runs under 8.90 it is DQ'ed?
novassdude is offline   Reply With Quote
Old 07-12-2011, 04:23 PM   #34
Dave Jung
Dave Jung's Avatar
Liked 5 Times in 5 Posts
No, they are confused. They are saying if you run 10.899 in s/st you are out.(wrong) Obviously if the other guy runs 10.895 the guy running 10.899 wins a double breakout race. This is a silly rule and should be changed back.
6535 stk
81 Malibu K/SA
Dave Jung is offline   Reply With Quote
Old 07-12-2011, 05:33 PM   #35
Phillip marvetz
Phillip marvetz's Avatar
Larry,
Putting personal feelings aside can you come up with a reason this rule should be followed based on the rulebook we all have to follow?
The problem I have with the track making this rule is the tech guy quoting a rule from another class of cars.
It would be like saying all stockers have to use an engine diaper because super comp has to.
2009 V/SA Record Holder
Old 07-12-2011, 08:20 PM   #36
bad man
Phil larry will never get it he doesnt run in sportsman and has no car that will run 12.00 .And if he gets one bring it out and line up next to me and phil and see how easy it is to run in sportsman. DON THE WORM ELGIN
bad man is offline   Reply With Quote
Old 07-12-2011, 09:12 PM   #37
Phillip marvetz
Hmmm,
I see a grudge match forming, Maybe I'll have to come down to Seattle this weekend. LOL
Old 07-12-2011, 09:19 PM   #38
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
I guess the next time you race there Phil,shut the car off at the 1000` in time trials and dial 12.20 for elims. No "offensive" breakouts will occur and you should be good to go. Just be ready for the slow car that disappears just before the stripe that`s on to you.
Lane Weber
Old 07-12-2011, 09:20 PM   #39
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
That's all well and fine,but let's put it into perspective of S/SS racing.I don't think guys should click it at 1000'.I don't see anybody looking to change that sceneario.Just saying.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 07-12-2011, 09:52 PM   #40
Toby Lang
Liked 2 Times in 1 Post
If they will let you dial 12.00 they have to give you some allowance to breakout.
I have an idea. Why don't they change the rule to say if you run faster than 11.90 you are DQ'd after one warning? Or if they are so concerned about cars running in the 11s, make the minimum dial 12.10 and a DQ for anything under 12.00.
What do you think about that, Phil?
-Toby
