Our bracket car is a 4000 pound Chrysler T&C. It runs low elevens and will eventually run low tens. The rear suspension is the original leaf springs, Rancho shocks and Caltrac bars. The front is stock with an old set of KYB shocks. The car gets decent 1.52 60' times but it leaves weird--the back of the car actually rises as it leaves. I'm planning on ordering up a set of the split mono leaves when I get a little time. Of course there is no such thing as front drag shocks for this big old boat. Any suggestions would be welcome!
Thanks Chris Barnes Wagons of Steel Stock 6621 |
#2 | |
Liked 503 Times in 131 Posts
Good luck
Eric Merryfield 1883 STK |
Liked 2,511 Times in 701 Posts
Chris:
Our Mopars with leaf springs ( prior to Calvert Bars ), due to shortness of front leaf segment and pinion angle, often looked like an elevator when they left the line. The short/stiff front spring segment worked like a traction bar. A lot of the time racers would remove all the rear clamps (Behind Axle Housing) which made the rear springs separate and feather out. For safety you should probably have the bottom spring clamped to at least second spring. I loved all the monkey motion, BUT Calverts are much lighte/adjustable/resistant to marginal track surfaces! Looking forward to seeing you again. John Irving |
#4 | |
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
I have a set of F body launcher springs laying around if you want to try them. They might work with the long Mopar spring mounts. or they might be just right for that AWB look, LOL
2009 V/SA Record Holder |
#6 | |
Maybe you can answer this; I seem to recall back when I had my Challenger about 25 years ago Direct Connection made a new front spring box that allowed the use of the SS springs that had shorter front segments than the stock springs. Does this sound correct? I wonder if something like that would be an easy option for Chris if he can’t just bolt in a spring from an A, B, or E body? He could maybe make new spring boxes for shorter springs??
Bill Edgeworth 6471 STK |
There were several different spring boxes available from Mopar to adapt
the 20" segment SS Springs to Different Bodies. Most of the other cars had around 22 to 24 inch front segment. However, I do not remember anything specifically C Body. I do not think any advantage to shorter spring other than to use the better engineered SS spring at that Time. We now use longer springs with the Calvert combo, as John prefers longer front segment. You can get most of the benefit of the SS springs on a budget by taking all separators out of springs and clamping all front spring segment individual springs to the next spring up and softening rear segment. Unless you just love the cool elevator action!! Last edited by GTX JOHN; 06-17-2011 at 09:57 PM. |
#8 | |
let's cut the front end off and graft a B-body front end on it, and shorten the wheelbase at the same time. No sense in doing anything if you cant over complicate it right?...lol
Well at least you don't want to put a mustang II front end in it. :-)
