Old 06-13-2011, 10:24 AM   #11
SStockDart
SStockDart's Avatar
Liked 574 Times in 212 Posts
Default Re: Car classification ?
The "lightweight" 1968 wheelbase is one inch less than a GTS. Therefore, the wheelbase needs to be 110". Regarding lightweight components, you do not have to have the acid doors, light windows, fiberglass fenders, or window straps. But you could have them. You would want the hood and the fresh air scoop, and it is legal.
Old 06-13-2011, 01:40 PM   #12
Stewart Way
Liked 70 Times in 22 Posts
Last time I talked to Bruce Bachelder on this, which was likely at least 2 years ago at the Southerns, I was told in order to run part of a package you has to run it all. If you want the hood scoop, the car has to tech as a SS/AH car with a different engine. At that time the windows could be changed to lexan or stock glass and the doors could be non-dipped. Same with the 64 cars. If you run the alum hood, you need the fenders too. This may have changed so a call to NHRA would be a good idea.
Stewart Way 2424 SS
Old 06-13-2011, 06:34 PM   #13
SStockDart
SStockDart's Avatar
It doesn't make any sense to have to put on fiberglass fenders only to have to add the weight back in somewhere else. Anyway, for what it is worth, a former Super Stock world champion is now running his 68 Dart in GT. Hood only. It is OK.....I am also considering my options with the lightweight hood also.
Old 06-13-2011, 11:47 PM   #14
will prater
Liked 7 Times in 4 Posts
Thanks guys for some things to consider and check out. At this time I now have an idea of where in GT the car should fall.
This car was originally built to run in the Nostalgia Super Stock classes so it has most of the AH setup, window straps, doors, fenders, lw glass, correct trim, etc but without the latest funny car type cage and rear suspension. Now I am concerned about having to meet roll cage requirements for the AH class specifications.
Stewart, I think we talked about doing this 2 years ago when I was trying to get a 383 rod approved by NHRA.
will prater is offline   Reply With Quote
Old 06-14-2011, 12:30 AM   #15
Stewart Way
Yes we did Will. As for the cage you only need to meet the safety requirements for the class you run. You will need a 8.50-9.99 cage in GT/A thru GT/G. 25.4 or 5 cage is only needed if you run 8.49 or quicker.
Yea, I saw the Dart at Vegas I think it was. Saw the front fenders had side lights but thought they still could have been glass. Guess not. As for it not making sense ( NHRA rules don't always "make sense") to have the glass fenders and have to add weight somewhere else, I thought thats why most people put lightweight componants on the front of a car, so the could "add the weight back in somewhere else". Thats why they are on my car, plus I was told they had to be.
Stewart Way 2424 SS
Old 06-14-2011, 06:19 AM   #16
Ryck Campbell
Ryck Campbell's Avatar
Liked 46 Times in 10 Posts
Gentlemen,
SS/GT is a little different than SS in that there is no "natural" class for a GT car. You take the heaviest model of your choosing (in this case the heaviest GTS is the 440 @ 3229; there was no Hemi in a 1969 Dart according to the class guide).
You divide the shipping weight of the car chosen and divide that number by the horsepower of your engine. In this case it's the 1970 383 - 330/335 rerated to 304 with OEM heads. That number is 9.80. Since GT/DA is a 9.50 weight break, you would be running at a .30 per horsepower disadvantage in GT/DA @ 3145 instead of at the top of the class at 3055. This car can also run GT/EA @ 3210, GT/FA @ 3360 or GT/GA @ 3510.
I hope this clarifies the way to calculate SS/GT weights.
Ryck Campbell
NHRA Technical Specialist
Ryck Campbell is offline   Reply With Quote
Old 06-14-2011, 10:12 AM   #17
Stewart Way
Ryck
The car in question is a 68, not a 69.
3 questions.
First, since the rulebook says you can adjust the weight a maximum of 250 lbs can't you remove 90 lbs to get to the 9.5 break? You could also run C at 9.0 or 2906 since it is less than 250 lbs from the natural 9.80 break. Not that you could get the car that light with a 383/440. Also, using your example, how can you run GT/GA at 3510 since that is 285 greater than the 3225 weight at 9.8?
Second question. Since we are talking 68, would you not use the Hemi weight of 3020 because the rule book says "by using the power to weight factor of the vehicle with the heaviest gasoline engine"? The Hemi is the heavieat gasoline engine. The rule book doesn't say use the "heaviest model", it says "vehicle with the heaviest gasoline engine".
Third. Almost hate to ask this one. If question #2 answer is use the Hemi factor for a 68, then would you not have to use the body equipment required on that car? Meaning you need the glass fenders as well as the hood. If the answer to 2 is "heaviest model', how can we add the glass hood (and fenders) since they were never on the 440?
Thanks for weighing in.
Stewart Way 2424 SS
Old 06-14-2011, 11:06 AM   #18
Jeff Lee
Jeff Lee's Avatar
Your verbiage may be off...but if not, then NHRA would have to know the weight of all engines and then you run into the issue of how to weigh them (exhaust manifolds, accessories, etc.). NHRA would need to know the weight of a slant-six and everything in between it and the Hemi.
I believe the accepted method of calculating is you use the heaviest shipping weight and if a 440 Dart is heavier than a Hemi Dart, then 440 weight is what you use.
I've communicated with NHRA on verbiage and they have changed the rule as a result. I'd suggest you do the same on this.
Jeff Lee 7494 D/S '70 AMX
Old 06-14-2011, 12:04 PM   #19
Stewart Way
Jeff
My verbiage isn't off. I don't have any verbiage. I'm just reading what NHRA has in its rulebook. But deep down inside I know your right on how they figure the weight. I messed up when I built my car. I built it to AH specs and used the 3020 weight and planned on running GT/D but with the heavier minimum looks like its a GT/F car and 305 lbs heavier.
Stewart Way 2424 SS
Old 06-14-2011, 12:56 PM   #20
Jeff Lee
Jeff Lee's Avatar
So the 383 2x4 using an old Wiend tunnel ram didn't pencil out?
