Liked 541 Times in 112 Posts
I had an odd experience at the recent event at Indy and was wondering if anybody else noticed the same thing. On two of my four runs, I noticed afterwards in the pits that both of my front runners on my Stocker had about 1/2" to 1" wide of gummy rubber (obviously picked-up from the track) all the way around the center of the tread. On one particular run, I was the first pair out after they had just swept and sprayed the track. I tend to think that perhaps NHRA is experimenting with traction compound again, correct? It can't be good results if cars are literally pulling the rubber up as they run down the track.
Jim Kaekel 3836 STK |
Liked 42 Times in 8 Posts
Yes Jim. It started there at the fall classic. Some of it is still on my garage floor from last winter! It is supposed to be sticky, but after the starting line it can be gummy and slick.
Sam Hamod 3456 STK |
I also experienced the same problem on a couple of qualifing runs. On one of those runs as I reached approximately 1000ft my car started to drift to the left quite a bit. Surprised me as the car rarely drifts that much. Although we had some wind I don't think it would cause that much drift. Run B/SA
Liked 232 Times in 39 Posts
Jim,
I had the same thing, but there was more sticky rubber on the left tire than on the right tire.
Marty Buth 3657 STK |
Liked 203 Times in 80 Posts
I had something sticky on my left front tire also.
Mike Fuller 396 STK 3961 SS |
Liked 1,006 Times in 204 Posts
It is from all that extra glue they put down on the track right before the stockers run!!!! lol
