#11 |
Liked 19 Times in 2 Posts
The 396/375 is a crate engine minus the crankshaft. It was just done slowly and policed fairly well as the aftermarket parts were put on. It doesn't sound like NHRA is presently in the business of slow, moderate, properly-factored changes.
Mike Ficacci Stk 1010 |
#12 |
Chipper think about SS/GT/HA. Your present shortblock should be legal as a 350 300 horse you have to change heads and carb. Should be able to run under index esp. IHRA. ...Thanx Trevor
#13 | |
Liked 1,788 Times in 408 Posts
My 427 pistons still look a lot like original pistons actually, but I'll agree they are better than the old TRW's. I guess my stuff isn't cheated up enough. My new aftermarket carburetor is no faster than my original. I don't think my new 359 is any faster than my good 163. I have to carry 75-80 pounds to put those 401 heads on. And honestly, I'm not sure they're worth it. Now, a current Stock Eliminator engine IS a well scienced race piece, I agree completely on that point. Actually, that's part of my point. You can't go BUY a crate motor, put it in, and be competitive. You still have to do exactly the same thing to a crate motor. At least, you do if you want to go fast. And it costs the same. The ONLY advantage to a crate motor, expense or difficulty wise, is not having to search for a few castings. If you build a new crate motor, and you don't put the trick stuff in it, like race bred pistons, big pushrods, and the rest, it'll be a slug. All of that stuff has nothing at all to do with the argument against crate motors, that's just a matter of racers cheating, and NHRA deciding to allow it rather than police the class. They don't want to tech to prevent it, so they let it in. NHRA has already proven they're not going to define and police anything. So why add a bunch of new stuff that they're not going to police and define better than what we already have? THAT is the problem with crate engines. They can come up with a new engine, on paper, with parts from a catalog, assign a soft factor to it, and start all over again, any time they want. NHRA will not add crate classes, they don't want more classes. Honestly, the majority racers don't want them either, and the class can't stand it. For crate engines to get in NHRA, they'd be added into the current classes. We already have bogus paper crate cars, we really don't need any more of them. I can sympathize with Chipper, having spent his money, and now being invested in something he's going to have a hard time racing. I hate to see it happen, to anyone.
Alan Roehrich 212A G/S |
#14 |
Liked 138 Times in 51 Posts
One other advantage to crate motors is that for many people, it's less expensive and a lot easier to find, as well as tune, a Holley carb as opposed to a Thermoquad or Quadrajet.
#15 |
Liked 11 Times in 2 Posts
Since I had one, I certainly won't blast the "crate motor stocker" concept. In my mind, however, CM cars are Modified Production machines much in the same way SS/GT rigs are actually Gassers. That's how they'd be interpreted in "old school" rulebooks, anyway.
#16 | |
But, if you want to find parts, you can find them. All you have to do is look. Yeah, some are easier to find than others. And some are cheaper than others. As far as carburetors go, it doesn't matter what carburetor you have to run, you're not going to buy one out of the box at the parts house, or buy a used one, throw a kit in it, and go fast. You're going to have one of the carburetor guys build you one. From there, tuning isn't that hard, regardless of what it is. If you chose a good carburetor guy, he's going to talk you right through tuning it.
#17 | |
Liked 1,102 Times in 301 Posts
#18 |
Liked 772 Times in 192 Posts
Alan and Rory, I do not disagree with most of everything you said. However, throwing another engine spec into the mix and another class formula is certainly not going to deteriorate the state of the class. And Alan, the point is not that the replacement parts are necessaily better, it's that the parts are not "stock" like Rory's production stuff is. If you spec a small block Gen I 350 Chevrolet with flat top pistons, a .450/.460 camshaft, 062 or 182 Vortec heads and allow a 750 Holley with an unmodified aftermarket manifold, then tag a relatively correct power number to it, what is the difference for tech, for classification or for the competition event?
#19 | |
Liked 166 Times in 71 Posts
I wasn't trying to piss anyone off with the original post, I just got to wondering if it had ever been considered. BTW, my ZZ4 Crate uses the exact same heads that a 1990 vette would in Stock eliminator, with 160cc runners, 1.94/1.50 valves, they are far from what everyone stereotypically thinks about CM heads. Just food for thought. |
#20 | |
Liked 64 Times in 14 Posts
The All stars run both NHRA and IHRA legal cars
Mark Callanan 1027 STK |
