#11 |
Liked 279 Times in 68 Posts
I thought the rule book said any corporate rear. I know several people who run aluminum spools.
Greg Hill 4171 STK |
#12 |
Banned
Liked 235 Times in 110 Posts
#13 | |
Liked 1,917 Times in 431 Posts
The only real advantage to an aluminum center section is a reduction in unsprung weight. Unless of course you use an aluminum 9" center section that accepts GM 12 bolt components. Once again, we have bigger issues than this in the class, this is merely another minor distraction. Do I think aluminum center sections should be legal? Not really, and certainly not if aluminum radiators and drive shafts are not legal for cars not originally equipped with them. Do I think aluminum center sections are a huge issue? Not really, so long as they are not the ones that accept 12 bolt parts.
Alan Roehrich 212A G/S |
#14 | |
Liked 138 Times in 51 Posts
Yes, 10lbs can be a small performance advantage because it can be relocated to a better location. But it's considerably less than the aftermarket brakes that are allowed! As far as unsprung weight, the benefit is negligible in a drag car. It would be a bigger advantage in Nascar, offroad, etc. where there is considerable and constant suspension travel. |
#15 |
This would be a good time to make the rules for Stock the same as Super Stock except for the engine and tires. Let roller rockers in stock, there is no reason to blow a motor up because you break a stamped steel rocker.
Tony Janes 7941 STK, SS |
#16 |
No thanks to roller rockers in Stock Eliminator. We've got enough "performance enhancements" already. Give them roller rockers and they'll just break something else. If you're breaking enough rockers to have a recurring problem, then something is wrong. We haven't broken a rocker in 6 years, and we average around 125 runs a year.
#17 |
Banned
UH OH......Ed. F. would not think so. Its moving toward S/S to much.......LOL. Just yanking your chain Ed to see if your awake today.
#18 | |
Banned
#19 | |
Liked 165 Times in 59 Posts
#20 |
The roller rockers is actually under consideration by NHRA
