Liked 251 Times in 90 Posts
I examined one of these at the NC International Auto Expo this weekend. Quite a nice little car. It would be interesting to see if Chrysler would want to attempt to get it accepted in the Classification Guide so it can run Stock.
Class Factors (Factory specs) 5M: 23.26 6A: 24.05 2012 FIAT 500 SPECIFICATIONS ENGINE: 1.4-LITER DOHC 16-VALVE MULTIAIR® INLINE FOUR-CYLINDER Bore x Stroke 2.83 x 3.31 in. (72.0 x 84.0 mm) Valve System Belt-driven, MultiAir, 16 valves, hydraulic end-pivot roller rockers Fuel Injection Sequential, multi-port, electronic, returnless Construction Cast-iron block with aluminum-alloy heads and aluminum-alloy bedplate Compression Ratio 10.8:1 Power (SAE net) 101 bhp (75 kW) @ 6,500 rpm (73.8 bhp/L) Torque (SAE net) 98 lb.-ft. (133 N•m) @ 4,000 rpm Max. Engine Speed 6,900 rpm (electronically limited) Fuel Requirement 87 octane (R+M)/2 acceptable 91 octane recommended DIMENSIONS AND CAPACITIES(B) Wheelbase 90.6 (2300) Ground Clearance 4.1 (104.0) Drag Coefficient (Cd) 0.35 Curb Weight, lb. (kg) 2,350 (1068.1)—5-MTX 2,430 (1104.5)—6-ATX SUSPENSION Front MacPherson suspension, coil spring with twin-tube shock absorbers and stabilizer bar—Included with 500 Pop and 500 Lounge Sport-tuned shock absorbers and springs—Included with 500 Sport Rear Rear twist-beam axle with coil springs and twin-tube shock absorbers—Included with 500 Pop and 500 Lounge Sport-tuned shock absorbers and springs—Included with 500 Sport WHEELS & TIRES 500 Pop & 500 Lounge 15 x 6.0 steel or cast-aluminum wheels 185/55R15 BSW all-season tires 500 Sport 16 x 6.5 cast-aluminum wheels 195/45R16XL BSW all-season tires |
Liked 6 Times in 4 Posts
Don't see much hope for it in Stock, but it would make one hell of a Pro Stock platform (That thing got a Hemi in it???)
Bill |
Liked 8 Times in 7 Posts
being a fiat, better stick to 1/8 mile tracks, i don't think it could run the whole length of a 1/4...
I could drive one into the back of my wagon and bring two cars to the track on one trailer!
Chris Barnes Stock 6621 |
Banned
Liked 235 Times in 110 Posts
Looks like you need two of them. One for each foot just like roller skates !
#6 | |
Liked 101 Times in 52 Posts
Liked 25 Times in 16 Posts
How about a Drag Pack version with the Viper V-10 rated at 300 HP, mid-engine mount with a ZF transaxle?
Mopar 2 Ya! |
Liked 13 Times in 8 Posts
Hope winter ends soon!
Cabin fever is making you guys NUTS! |
Banned
