#81 |
Liked 32 Times in 19 Posts
Alan, Extremely good post. Thank you.
#82 | |
Ed there were 2 stick cars and Chevy A GO GO modified stick car out of an 80 car field at the Reading Nationals last year. I don't think 2 cars avoiding heads-up runs is the problem. We need more ESPN2 exposure.. how do we get it? Tell me who to petition to and I will. Last edited by Bobby Fazio; 01-29-2011 at 09:02 PM. |
#83 | |
Ed Wright 4156 SS/JA |
#84 | |
Liked 520 Times in 132 Posts
#85 |
Liked 5 Times in 3 Posts
change the wt break inSuper Stock to 6.00 to15.00 pounds per hp, for both SS > eliminate modified classes , Super Stock is for factory production avaliable cars with with production spec engines..Modified belongs in comp.This format would make for closer racing with hadicaped e.t.'s of 8sec to12 sec Stock because of its entry level draw must have 1 pound breaks from 6.00 to 20.00 pounds per hp. With handicaped e.t.s of 9.00 to 16.00 both stick and auto run together all auto cars get the 3 speedsautos. concerning the modified class they can easily build a Super Stock spec'ed engine much cheaper or go and run heads up in comp.Nhra needs to get their hand out of the cookie jar and let all the contigency monies go to the guys that support the SEMA manufacturers.Let the SEMA sponsors set up either a cash or voucher system handled directly between them and the racer and have flexibility as to sponsor when or where it benifits their products marketing either by a race or geographical area. LET THEM SET THEIR SPONSORSHIP however they want FLEXIBILITY IS THE KEY.......just my 2 cents
#86 |
Liked 10,681 Times in 2,222 Posts
Lower the contingency sponsor fee to $250 for the administration fee. Only have sponsors pay for what is won for class and or the eliminator.
Have the product registered with the sponsor in their data base. Verify that product decals are displayed. View falsification of product use as a serious rules infraction carrying a penalty of 90 day suspension for first offense. Enforce the rules as written. When rules infraction are noticed ,competitors should have a choice on fixing the infraction. Fix it now and race or go home and fix it before the next race. This should eliminate discussion on east coast, west cost rule books. It is the racers responsiblity to comply with the rules. Remove and or correct mistakes made by tech. department that gives a combo a distinct advantage. IE. Reduction in stock crank pin size from 2.437 dia. to 2.200 dia. Class winners first, then the remainer of 128 car field filled by higher qualifers. This will help us keep our diversity in the eliminator. People in the stands enjoy seeing new, old and differant. Get the Hp. correct on all the new cars. Yes tech. missed it the first time. You know how bad it is when Dan Fletcher changes combos mid year so he can try to provide for his famliy. Dan qualifed 129 at Indy this year. Bottom line: treat the sponsors fairly and thank them for there financial support they give to the class racer. |
#87 | |
Marvin Robinson 3188 STK/SS Last edited by Marvin Robinson; 01-31-2011 at 04:53 AM. |
#88 |
I understand that my previous posts have been removed as too controversial but all the comments without identifying the issues first is less helpful. Larry Hill discussed the factoring problems, some have identified the bye runs and others the announcer, the NHRA lack of publicity and sponsor money.
Individual fears about losing a place to race " the type" car they already know and own is a problem also. There is only one place these can be solved and thats with honest NHRA evaluation and corrective actions. THEY know the sponsor issues, they have been told the factoring issues, they control the epansive classes and combinations. To Keep the identity of the S and SS as we know it, the basic rules must be preserved To Keep fresh combinations being built they need the lower "guestimates" of HP but they MUST watch the performance or start them out as individual class (Like happened after several years of FI versus Carb) Racers must accept that even though they found "the car", " the technology" to be fast or efficient, changes may come for the overall good of the S and SS Class structure. NHRA should recognize that if Sponsors budgets are limited by the Per class demand, then either cut the costs or cut the classes to be fair to the budgets of the majority of sponsors. The pool of money left after paying winners should be less important to their budget than the overall success of the program. NHRA must recreate their view of the AHFS and its application. Create a method to encourage performance every run not 1000 ft racing to save the HP. Reward each winning run more than punishing with HP factors and it becomes worth it to get factored. Post Performance leaders each week in Dragster as "reward" for going fast. This would be like seeing your name on 16 top qualifiers at an event. Points towards championship for Records , no factor. If you use the Et to WIN money then Hp factoring would seem more reasonable. Cost to race is an issue, technology advances and rule "drift" upwards IS A FACTOR for all racers, now more than last year or prior. NHRA could Cut the number of events used toward Championship points per division or National to give option to save one trip costs per racer. OR have double meets at large track by running eliminator twice. Same qualifying sheet. One set of time trials. Cost per car could be addressed if people would accept change but these are some thoughts without those issues. Thanks for reading. |
#89 |
Liked 1,916 Times in 574 Posts
There are probably more single runs in the stick shift classes. I would combine the sticks and the autos. I would adjust the HP factors to be the same in the stick and auto classes. then monitor the results to see if one or the other should get a weight adjustment to make things as competitive as possible. I also think class should be run at every national event. This alone would stimulate car counts and more participation from the sponsors. Class runs would be run during qualifing. it usually never takes more than 4 rounds to complete class.
It just seems like the leadership that we have running thing now likes to make change for change sake. Every year they make changes that no one really wants. even some of the safety changes they have made recently seem unnessesary.
Mike Pearson 2485 SS |
#90 | |
Dick, you and I come from the same era. I remember racing at IRP and Edgewater Raceway Park with you back in the 1970's. I too started racing seriously in Super Stock with the goal of winning class at the US Nationals because it was the only you could make the eliminator on Monday morning and that's where I wanted to be. In fact, I don't remember ever running Super Stock eliminations without winning class when it was available. Then came class winners plus qualifiers to make a full eliminator field. I too got tired of the HP factoring, replacement oem parts and so on. That's when I built a weight to cu in SS car and ran SS/AM. During that time I was also a NHRA Major sponsor, running full page ads in National Dragster and paying class winners and comp qualifiers. Then I moved to Comp and enjoyed reasonable success there just as I did in Super Stock. Those days were far different that when we raced in the 1970's just as next year will be different than last year. Every time detroit builds a new car, there will be new classes created and more technical issues to deal with. The bottom line is this..... Stock and Super Stock racing cannot and will not continue "as it used to be". For every racer and NHRA, last year is in the past just like the 70's 80's and 90's and that is where it's going to stay. The question for racers and NHRA alike is "how do we deal with the issues we face today and tomorrow". Dick, I think your post is perhaps the most accurate and realistic one I've seen on this issue. You addressed the real issues and as far as I am concerned and you addressed the core of the "problem" in your last sentence..... "if people would accept change". This whole debate is about people resisting change. It's human nature to resist change. I too would love to see competitive class racing like it used to be but the economic environment just cannot support it any longer. I predict that class eliminations will be a thing of the past in just a few short years. Stock and Super Stock will fall into the same format as the other catagories..... qualify, pair up on the ladder and fire up for round one. For NHRA, class eliminations and all of it's overhead.... tech inspections, tear downs, HP factors, weight breaks, superceded parts and all of the employees and expense required to administer the program has become a major headache.
Scott Wilcox 2193 3x National Champion SS/A, SS/B, SS/K, SS/L, SS/AM, A/SM, C/SM, B/A, C/A, G/A, H/A |
