Liked 880 Times in 311 Posts
Longacre Lon78262 GM caster and camber gauge w/case Jegs $121.50 Pictures available.
New never used $75.00 Autometer Ultamate 11 Playback Dual Ch. Tachometer # 6883 Complete w/download Computer disc, drive yoke magnet collar and shift light This is a complete 2 channel data system used only a few weeks in my A/ED before I sold the car. Pics. available on request. $475.00 SOLD 1.82 Straight Cut Gear set for Powerglide Gear set came in a new A-1 Powerglide and I never used that ratio. Went to a lower ratio set. Pic. Available $645.00 GM Performance Parts Race Block Item #: 12480046 Busch Series Block Description This is an early GM CNC Nascar Block that has the 350 main size. This block has a serial numbered & dated GM Motorsports CNC Specification sheet and Sonic Test Report Competition tested in NASCAR BUSCH and NHRA competition eliminator. Only GM Performance parts can offer you such a huge selection of race blocks that have been precision CNC machined with tighter tolerances than Bowtie blocks. These blocks feature full race prep machining, 4 bolt splayed main caps, and the very highest grade materials throughout. Notes for race blocks: · Machined to .001" tolerances · Cylinder decks, front and rear of case, oil pan rail surfaces and head dowel pins are blueprinted! · Non standard cam bearings required (see notes below for details) · Cam bosses are enlarged to allow machining for the use of larger cam bearings · Extra thick main bearing bulkhead machined at 5 degrees · Premium quality studs and SAE 8620 steel main bearing caps · Billet wet sump rear main cap can be adapted to dry sump with plugs · Bearing cap inner bolts are spread .210" to allow machining for the use of 400 journal crankshafts · Priority main oil system · 2-piece rear main crankshaft and pre-1986 oil pan required · Extra thick deck surfaces with blind tapped head bolt holes for improved head gasket sealing · Cylinder bores have a nominal wall thickness of .340" · .225" minimum cylinder bore wall thickness at 4.155" bore, sonic bore test data sheet included with each block · These blocks may require clearencing of the tops of the lifter bores for some aftermarket mechanical roller lifters · Lifter valley oil scavenging boss behind cylinder #8 below bell housing flange is not drilled and tapped · Oil dipstick holes are not drilled Specifications for this block: CNC machined, cast-iron NASCAR competition block 350 in size mains 9.025" deck height 4-bolt NASCAR specific steel mains, 17 degree splayed caps on center three mains 4.115" rough bore 4.185" max bore Siamese bores Machined for 58mm roller cam bearings .875" lifter bores 6 AN coolant drains 45 degree 10AN front oil feed gallery scavenge port AN O-ring pipe plugs 4 center lifter valley drains (drilled & tapped) Steam holes drilled between cylinders .750" below deck surface 1/2" NPT coolant hole on each side of block Dry sump only (no filter boss) Tested to over 800 HP Includes GM sonic test sheets Current PACE Price: $6801.31 Current Scoggins Dickey price: $4,395.00 My loss is your gain price: $3200.00 Adger Smith 903 794 7223 shop 903 824 4924 cell
Adger Smith (Former SS) Last edited by Adger Smith; 01-17-2011 at 02:55 AM. Reason: add # |
Liked 216 Times in 77 Posts
Do you happen to know the Autometer number for the tach?
If not is it a 9K or 11K model and does it have a silver or black face? What rear does the Yoke fit? Thanks |
Liked 694 Times in 206 Posts
Rob sent you a PM
11,000 rpm with a black face / white numbers # 6883
I have a very nice close up picture if you would like to see it.
Adger Smith (Former SS) Last edited by Adger Smith; 01-10-2011 at 02:03 PM. Reason: sp |
