#11 |
Keep in mind when a Ti valve breaks the carnage can be twice as bad. Maybe that's why the engine builders want it?
Jeff Lee 7494 D/S '70 AMX |
#12 |
I am for them in both super stock and stock(Jr Super Stock), It is a choice, no one is making a person us them if they do not want to.
Tony Janes 7941 STK, SS |
#13 |
Liked 695 Times in 206 Posts
Already allowed in many S/S classes. SS/AS, SS/BS, SS/CS. Probably others. Dyno
#14 |
Banned
Liked 235 Times in 110 Posts
#15 |
Liked 244 Times in 26 Posts
Exhaust only or intake too? BTW, other OEM valves have hollow stems too. You should see the hollow intake valve heads that are lazer welded together, neat stuff.
#16 |
Banned
#17 | |
At the time the rule was implemented for the Ford 427, there were no other OEM applications with Sodium Filled valves. |
#18 |
Banned
#19 |
Terry that is what they are in 2010. Should go a little farther with the rules. Same as S/S except for 9 " tires, stock manifolds and stock valve lift.
#20 |
Banned
