#21 |
Banned
Liked 235 Times in 110 Posts
You should have to win class to run the eliminator like when I was racing up until around 1978. If you dont win class then you dont deserve to run the eliminator. The AHFS would take care of those underrated HP factors in a hurry if they did that and put the PERFORMANCE back into stock and S/S. Just my 2 1/2 cents.
#22 |
I do not agree with that. I would say at this time neither does NHRA.
Tony Janes 7941 STK, SS |
#23 | |
Liked 1,921 Times in 432 Posts
If they'd run class everywhere, go to 1 pound weight breaks, and most importantly, make it pay money and points to win class and qualify well, then you'd see performance come back and the AHFS start working. That wouldn't force a situation where most of the cars would never make it to the final eliminations. Because if you did that, you'd keep most people home and kill the whole thing in a year.
Alan Roehrich 212A G/S |
#24 | |
Liked 229 Times in 71 Posts
#25 |
Can someone enlighten me as to the advantages of a 1 lb. weight break? I fail to see how that fixes anything. Sounds DECENT for a lower horsepower car that might have to add 200-300 lbs to move between classes, but what about the high horsepower stuff?
Example: '10 Super Cobra Jet rated @ 500 hp. 6.00 lb. class = 3170 lbs 7.00 lb. class = 3670 lbs I for one would not like having to find/remove 500 lbs. of weight to change classes. Is that the idea? To keep people in one class? I'll say this much: that'd keep the Belvedere locked away for the rest of its life. I can't get to 3170 and I don't feel like turning it into a lead sled.
Jared Jordan 9 B/SA 2024 Jeg's D7 All Star - Stock |
#26 | |
Liked 55 Times in 14 Posts
x-tech needs to get out of the 70s or go to the nostalgia drag racing board. |
#27 | |
Jeff Lee 7494 D/S '70 AMX |
#28 | |
Banned
#29 |
Liked 13 Times in 9 Posts
I agree that that's a bit much to ask for shuffling weight. Well, then, a little common sense should be used. Fine, keep half-pound breaks for the very upper classes, then go to .75lb breaks a little further down, and then to full pound breaks. I have to move ridiculous amounts of weight to move classes in FWD, and sticks n' autos are combined. Y'all can do it, too, within reason. If classes have indexes that are the same or within .05, then they can be combined. I made a spreadsheet before that showed how you could readily combine a *significant* number of classes. Less classes = more heads-up runs or "class racing".
I find it odd/comical/sad that I'm the *bracket racer* here, and so many of the hard core "class racers" run screaming to protect their own interests when you actually try to do something to bring the class racing back to class racing. Too many of them like to just pretend they are performance-based racers. Pretty darn rare for me to do a 1000' dump in a bracket race! ![]()
#30 |
Thank you Jeff, I forgot about records. You're correct, records should be worth points.
