Old 06-12-2010, 07:34 PM   #21
pro70z28
Default Re: Firewall Project
Got the inlet side roughed in today.
And got a panel installed.
I roughed up the back of the panel & the chassis tubes with 80 grit on the angle grinder, then glued it in with fusion body panel adhesive.
pro70z28 is offline   Reply With Quote
Old 06-13-2010, 07:18 PM   #22
pro70z28
Added a couple more pieces to the puzzle this afternoon.
Old 06-14-2010, 10:27 AM   #23
NewHemi
NewHemi's Avatar
Wow, that is some nice work!!
You obviously have some things that I definitely lack; skill and patience..
Keep going. This is going to be an swesome car, and hand crafted beauty.
David
The New Hemi Guiy
NewHemi is offline   Reply With Quote
Old 06-14-2010, 10:44 AM   #24
Jim Craig
Liked 5 Times in 3 Posts
that's some pretty nice looking stuff there......you need to take your pictures and start a thread on yellowbullet (in whatever power-adder you're using). The guys over there are a little rough around the edges, but there's a whole 'lotta knowledge to share and they'd also appreciate your handi-work.
Jim Craig is offline   Reply With Quote
Old 06-15-2010, 08:41 PM   #25
pro70z28
Thanks Jim & Dave
Old 06-20-2010, 09:04 PM   #26
pro70z28
Everybody (but me) had to work this weekend, we celebrated Father's day Thursday, so I had the weekend to work on the firewall. Got a fair amount done.
Since this WILL be a street legal car, I found a new spot to display the trim code tag.
I stuffed it between the strut tube & the inlet side of the intercooler.
Also made paper patterns for a couple more pieces of the puzzle.
Old 06-20-2010, 09:16 PM   #27
pro70z28
I decided to stamp a "Camaro: logo in the driver's side panel
The press and bead rolling oil canned the panel a little but I think it will straighten out when I put the 7/8" tabs on the top & bottom with the brake.
It came out fairly clean, even the little piece in the top of the "o" stamped. That part was about 1/2 the size of a pencil eraser. When I paint the firewall I'll paint the logo over this, the stamping will give it a little extra "pop".
Old 06-25-2010, 09:42 PM   #28
pro70z28
The more I looked at the Camaro panel the more things I found I didn't like. The deal breaker was when the bead rolled lines didn't match up to panel next to it. So, tonight I knocked out another one. It didn't take long since I had the stamp & measurements from the first "prototype". [ prototype = politically correct term to describe "junk part"]. I had to lay the panels in place to see how it was going to look. There's a lot of massaging to be do to get everything to fit, but it is getting closer.
Old 05-31-2011, 01:12 PM   #29
pro70z28
Sorry, haven't been around for awhile. The "Z" project has pretty much sat since last summer, but I got some time the last few days to get the firewall welded & in primer.
Got the front end set in place. Next project is to fit it to the car, fabricate hinges, tree & latch system.
Old 06-11-2011, 07:59 PM   #30
pro70z28
I started on the hinges but then decided I better get the front end straight first or the hinges would be wrong. (The front end is a mess) The nose didn't even come close to fitting, so I trimmed the opening & made cuts where I had to, to get it to match up
I used some scrap aluminum from an old sign to get the nose in the right place.
Glassed the blank spaces between the gussets. After it sets up I'll unscrew the gussets & finish the fiberglass, a job I'm just itching to get done. lol
