Go Back   CLASS RACER FORUM > Class Racer Forums > Top Sportsman and Top Dragster
Old 06-05-2010, 07:13 PM   #1
drgrcr1156
Liked 2 Times in 1 Post
Question Advice using TH400 with clean neutral
I am considering a Coan Big Dog TH400 with clean Neutral pro tree brake and looking for racers who are currently using one to share any isssues pro/ con. Can it leave against a .400 pro tree? Currently I have a Griner aluminum pro tree trans brake in a mild TH400 behind a 468 BBC but am moving up to a 565 and will need a more substantial trans. The car itself weighs 2450# but I am concerned with how quick it can leave and the benefits (or problems) with the clean neutral setup.
Any .02 welcome.
Thanks
Bob
drgrcr1156 is offline   Reply With Quote
Old 06-07-2010, 06:35 PM   #2
RACER1530
RACER1530's Avatar
Send a message via AIM to RACER1530
Default Re: Advice using TH400 with clean neutral
Use a powerglide,turbo 400 has too much low gear.If you look around most use a glide with a few running a lenco.The glides will handle a lot of power,my friends car goes 6.50@209 with a glide.
Fordyce Motorsports
SC 1538 / SC 153R
RACER1530 is offline   Reply With Quote
