Old 03-31-2010, 06:36 PM   #11
Stewart Way
Liked 70 Times in 22 Posts
Default Re: AJE wheelie bars ?
Almost hesitate to enter into this for fear of being accused of b..ching but...Oh Well. Stock started allowing wheelie bars in 2002 I think. The wording has always been the same. Can not be attached to anything but the rear end housing. SS at the time had wheelie bars but it only stated that they could not be attached to the rear bumber of braces and it still reads that way today. But if you read the start of Super Stock it states that SS uses the same rules a Stock except where noted in the SS section. Nowhere in the SS section does it say that any part of the wheelie bar can be attached to anything so the rule from Stock applies to both Stock and Super Stock.
Just my read on the rules and as we know, opinions vary.
Old 03-31-2010, 06:43 PM   #12
Liked 11,033 Times in 2,268 Posts
I would like to thank Ralph Popora for allowing me to look at some length at the AJE bars on his car. It was a lot of engineering in a very small space and nicely done.
Old 03-31-2010, 07:37 PM   #13
Barry Polley
Guest
Posts: n/a
This does not make any sense... What differance does it make if the bars pick up the diff and the upper body? Is it unsafe? No. Is it an advantage? No. Is it lighter? No. It is a differant approach for the same result. If anything it is a better approach to an outdated design. How about all the wheelie bars that are clearly too long for the car they are on. Very easy for a Camaro, Mustang and Mopar guy to see this...
Barry
Old 03-31-2010, 07:37 PM   #14
Rory McNeil
Originally Posted by Robert Simpson View Post
What brought all this to light? I have seen these bars on Calverts cars for years? While I agree with the clairification. Did I miss something in the rule book about welded on sway bars? I have seen links and attachment points welded to the frame? I don't mean a coil spring car with a bolt on sway bar. I mean a leaf spring car with a sway bar control system on it? I don't know if that is legal or not? It has been several years since I have seen the photos of the cars in question.
Robert
Although John Calverts Mustang has been equipped with AJE wheelie bars for several years now, it has always been as a Super Stocker. I don`t believe that he ever had the bars on when it used to run in Stock.
NHRA 6390 STK
M/S 85 Mustang
Old 03-31-2010, 08:25 PM   #15
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
I may be missing something, but the way the bars are designed they act as a lever with the fulcrum in the middle, not at the axle. If you push up on the wheel end it pushes DOWN on the end attached to the axle. On a normal set of bars the fulcrum is at the wheel end, lifting the axle.
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
Old 03-31-2010, 10:19 PM   #16
Jeff Lee
Jeff Lee's Avatar
I think I started running them on my D/S AMX in 2005. I never even thought it could be a problem. D7 tech never said a word (and I know, past acceptance is not presedence).
Jeff Lee 7494 D/S '70 AMX
Old 04-01-2010, 09:30 AM   #17
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Here is my fix for the problem.
Weld a bar across the chassis with two pads on it, weld a strut at the fulcrum point with a pad on it. Gap the pads 1/8 inch. The bars will need to be attached solid to the rear instead of bolted. They should still work at the fulcrum point.
Bob Pagano A/SA
Old 04-01-2010, 10:53 AM   #18
Bill Kennedy
Bill Kennedy's Avatar
Liked 37 Times in 11 Posts
If any one needs a set, I have a set that I would sell.
Bill Kennedy 1671 SS
Bill Kennedy is offline   Reply With Quote
Old 04-03-2010, 11:15 AM   #19
magnumv8
I remember when the AJE bars were first brought to market and reading the tech information and seeing the photos of them installed and the theory of their operation.....while they are similar in appearance and do give you "wheelie" control they are considered a traction device and NHRA did not allow them to be used in stock....they have never been legal.....and if you read the general regs 3.6 you will see that they aren't legal in superstock either....they must be "fixed" at the attachment point and cannot pivot.....
pretty much black and white to me...no grey area there.....
D L Rambo.....
magnumv8 is offline   Reply With Quote
Old 04-03-2010, 12:42 PM   #20
Ernie Neal
Ernie Neal's Avatar
Liked 328 Times in 80 Posts
D L Rambo.....
I beg to differ; they are devised for wheelie control only! If you don't have traction you don't even need them.
Ernie Neal
SS3400
