Old 04-01-2010, 05:53 PM   #81
Racer 6x64
Default Re: oil retention devices
Jeff, I am a paid member of both the NHRA and IHRA and posses a competition license in both as well. I am not sure how to take that statement. Are you asking me to leave the forum simply based on the fact that I am not class racer? Or just making me aware that the NHRA rep is not interested in hearing any pro's or con's from a non-class racer?
C. P.
2015 Drag Pack Challenger FS/C
Racer 6x64 is offline   Reply With Quote
Old 04-01-2010, 06:13 PM   #82
Angelo DiTocco
Angelo DiTocco's Avatar
Liked 189 Times in 48 Posts
Why not just legalize Dry Sump systems? That would at least have the added benefit of improving performance.
And VIc S......... 11 quarts ???? ...you sandbagger!
If you cut it back to like 8 quarts it might cool down a little bit quciker & Just think of how much weight you'd save LOL
Angelo DiTocco
'98 Firebird SS/HA
'98 Firebird B/SA
Angelo DiTocco is offline   Reply With Quote
Old 04-01-2010, 07:09 PM   #83
Vic Santos
Vic Santos's Avatar
Liked 14 Times in 2 Posts
Jeff Lee: Sorry but my old eyes glazed over at about posting #35. We are in total agreement.
Racer6x64: The oil temperature issue is: the hotter the oil the thinner it is. The thinner it is the it's ability to protect the engine is lessened, oil pressure is lowered, oil flow is increased (emptying the pan quicker) and more oil migrates into the cylinder. Once all of these changes are dealt with there is no "issue".
Angelo: Remember all of those engine changes Dean and I use to do? I was running 8 qts. 11 is much better and cheaper!
Vic Santos is offline   Reply With Quote
Old 04-01-2010, 07:20 PM   #84
Jeff Lee
Jeff Lee's Avatar
Just what I made in bold.
Jeff Lee 7494 D/S '70 AMX
Old 04-02-2010, 11:26 AM   #85
NewHemi
NewHemi's Avatar
Does that mean that the NHRA ACTUALLY DOES CARE about what class racers have to say?
Just asking...
David
The New Hemi Guy
NewHemi is offline   Reply With Quote
Old 04-02-2010, 11:45 AM   #86
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Thumbs down Re: oil retention devices
Just asking...
David
The New Hemi Guy
LOL.....Yeah just like the Dems over the health care issue.
Old 04-02-2010, 04:22 PM   #87
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Since I have involvement with both S/SS cars and .90/ Bracket cars ,I have a few points to make............I've run a diaper on my SG car for the last 6 years , I can tell you oil temp is not an issue,but cooling the car between rounds is. .....When the hot lapping starts ,I'm lucky to get the coolant below 160 deg..The oil temp stays around 180, which is where I want it. [btw ,I run 5w30 ,not 50w] ..look at any of the racing oil sites ,or ask someone who spends a lot of time on a dyno ,You'll find the optimal temp for oil is 180 to 200 deg.........Is the diaper a pain to work around at the track, you bet! ..............does it drag on the ground in the pits or on a wheelie ,you bet......Do I want to put on on my Stocker [ or any of the S/SS cars I work on ?] ,No Way.,even tho having one probably saved my SG car a few years ago..............I will say this, I think ATF leaks are a far bigger problem than the ocasional oil down from a S/SS car. ...........That's a problem that can be corrected with a $30 puke tank , [ and I wont have ATF dripping on my head when I work on cars with Metric 200's ]...............Tom
Old 04-03-2010, 12:06 AM   #88
Jim Bailey
Liked 584 Times in 94 Posts
Cool Re: oil retention devices
I've been involved with Diapers since they became manditory. My Alky F/C never had one. Every engine/rod failure with my Top Fuel Car(s) and since working on Jim Head's Funny Car results in and saturrated over flowing diaper. THE ONLY thing that saves an Oil Down is a correctly designed and sealed belly pan with fore and aft baffles to stop Oil Shosh. After we hang a rod out we carefully let down the belly pan that is usually full of oil along with the soaked diaper. This is the rule not the exception with Nitro Cars. Did I mention we run Dry Sumps? IF diapers were the cure all, then why are there still oil downs with the Nitro Cars? Why are belly pans manditory also? My feeling's are quite simply that a "universal" Diaper for stock/ss is impossible. The containment is too close in proximity to the headers and the risk for fire is multiplied. I personnelly will not run a diaper on my car WITHOUT an on board fire system. When they pulled Al DaPasso out of his Alky FC in BG , KY in 1992 the meat (muscles) of his lower legs were hanging off the bones like a cooked chicken. ( He died several weeks later.) I prefer for that not to happen to anyone ever again. MY point ? I hate Fire. Hit a guardrail,... spin out,... flip........NO problem .....I hate fire.....What's next? Fire Suits, and Hans Devices? Give me a brake! ...PS... for all the non Vietnam Vets out there, Go on line and look up how Napalm is made; Take a little Gasoline, Mix in a little Aluminum, add some Oil, etc. etc., sound Kinda like the contents of an oil pan? JB.
Jim Bailey is offline   Reply With Quote
Old 04-03-2010, 06:50 AM   #89
joe176
joe176's Avatar
Liked 41 Times in 9 Posts
Great Point Jim !!!!!!!!!!!!!!!!!!!!!
Joe Franco SS176
joe176 is offline   Reply With Quote
Old 04-03-2010, 08:01 AM   #90
John Leichtamer Jr
John Leichtamer Jr's Avatar
Do any of you remember when Rich Pica punched Bob Lang???????
Ha should have hit him harder to knock some sense into him.
Hammer
John Leichtamer Jr is offline   Reply With Quote
