Old 01-01-2010, 03:33 PM   #11
Tony Curcio
Tony Curcio's Avatar
Liked 4 Times in 1 Post
Default Re: merge collectors ?
Originally Posted by gmonde View Post
what was the size on the merg collector vs the straight collector i know from the o2 sensor just by adding collector extensions(14") on 3 1/2 hooker headers it changed the afr by.13.00-12.50 and it picked up in the 60 ft and the bung is close as i can get to the primary out lets as possible ,,,your merge collector does it choke down??? or is it the same size as the straight ??? gmonde
The straight collector is 14" long by 3" diameter.
The merge is 8" long, the narrow part of the "venturi" is 3.0", the outlet is 3.5".
Tony Curcio 1860 STK
Tony Curcio is offline   Reply With Quote
Old 01-01-2010, 03:41 PM   #12
72Malibu
72Malibu's Avatar
I have found that, Usually, lower compression engines make more power on a little richer mixture.
They can also like a degree or two more timing than the same combo with hi compression
I am far from scientific in any of my tuning, no afr meter, no egt, just tuning on my 10.5-1 alum. headed big block. I run my timing locked at 40* and the 1000hp is jetted 87/92 w/ rear pv blocked. It falls right in line with the fat/advance statement made above
*** 72 Malibu ***
1.329-3.99-6.28@106.71-9.98@131
best 60ft to date-1.2997
72Malibu is offline   Reply With Quote
Old 01-01-2010, 07:53 PM   #13
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
whats the cubic inch on the engine and i assume its a stocker ,whats the primary tube size ? doing some research gmonde
Old 01-01-2010, 08:39 PM   #14
72Malibu
72Malibu's Avatar
Mine is 505 cubic inch, 2" tubes, just a bracket racer.
*** 72 Malibu ***
Old 01-02-2010, 11:27 AM   #15
Tony Curcio
350 c.i., 255/280 HP stocker. Step headers with 1 5/8 to 1 3/4 tubes.
