Old 10-24-2009, 06:43 AM   #31
Liked 1,922 Times in 432 Posts
Default Re: Drag pak Challenger
I wish FARMER was still in charge.
Be extremely careful what you wish for. I seriously doubt that you'd love the next "benevolent dictator" you'd get from NHRA. I'm not sure anyone likes the one we have now, or any of his "deputies".
Old 10-24-2009, 08:20 AM   #32
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Farmer......if only, at least with him in charge you knew where you stood. It was right or you were out. His way or the highway and there were no if and or buts
Bob Pagano A/SA
Old 10-25-2009, 05:57 AM   #33
GUMP
Originally Posted by Bob Pagano View Post
NHRA did not allow the vettes to mount a 12 bolt like that, it was shot down long ago. Now it looks like anything goes.
The biggest problem with these cars is that the stock control arms swing in the wrong direction. The factory supplied this design. I can't see where its any better than what's under an earlier Corvette.
Take Care,
Daren
Old 11-04-2009, 07:40 PM   #34
DonatoEng
Liked 8 Times in 5 Posts
NHRA requires that the stock shock and spring mounts on the body must be used for an independent suspension conversion to solid axle in Stock. The Challenger uses these with specific locations for the upper and lower control arm mounting holes on the body and axle ends. The rear suspension layout is based on a production Chrysler vehicle
The Corvette has the odd spring setup to meet these requirements.
DonatoEng is offline   Reply With Quote
Old 11-09-2009, 08:59 AM   #35
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
Thank you !
Thank you very much, I am not irritated by much. I have been irritated by all the items (not here) on this issue.
Thank you.....
Chris "drooze" Wertman is offline   Reply With Quote
Old 11-09-2009, 05:07 PM   #36
Mack Reeves
Mack Reeves's Avatar
Liked 44 Times in 13 Posts
Originally Posted by drooze View Post
Thank you !
Thank you.....
X2....... Mack #43
Mack Reeves
2377 STOCK & SUPER STOCK
Old 11-11-2009, 07:29 PM   #37
Sam Murray
Sam Murray's Avatar
Liked 60 Times in 29 Posts
Makes Wiebe A body suspensions look stock!
Sam Murray
1616 STK
Sam Murray is offline   Reply With Quote
Old 11-11-2009, 07:44 PM   #38
SSGN
SSGN's Avatar
Liked 203 Times in 52 Posts
Cool Re: Drag pak Challenger
Enough said!
