Old 09-18-2009, 07:17 AM   #1
Michael Pliska
Default Which Powerglide Trans Filter?
What are people using these days for a trans filter? If using a stock type, what vehicle application is it listed under at the local parts store?
Thanks,
Michael Pliska 643 S/G
Michael Pliska is offline   Reply With Quote
Old 09-18-2009, 08:36 AM   #2
FED 387
Liked 335 Times in 182 Posts
Exclamation Re: Which Powerglide Trans Filter?
WE USE THE FILTER THAT LOOKS LIKE REAL FINE NYLON? MESH SORT OF AS FINE AS PANTYHOSE----WE HAVE FOUND OUT THAT THE FIBER? (LOOKS LIKE COTTON) GETS SATURATED AND PLUGS UP TOO EASILY---NO SPECIFIC AUTO/YEAR APPLICATION--YOU JUST HAVE TO LOOK AT THE FILTERS--MAYBE GO TO A TRANS SHOP SEE WHAT THEY HAVE---sorry for the caps we type everything in CAPS at work---forgot to turn it off!!!! Comp 387
Old 09-21-2009, 03:35 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
Default Re: Which Powerglide Trans Filter?
The OE type works fine for most PG applications. .....NAPA has the OE bronze screen type , P/N ATP13998. ....About $4, It's what almost every trans mfgr. uses except for the pan kits that relocate the filter rearward and use an early Torque flite filter.....I also avoid the fiber type filter,altho some mfgrs. recommend them for use with aluminum drums . ............Tom
Old 10-06-2009, 07:08 PM   #4
S/C 302A
S/C 302A's Avatar
Yes, the bronze screen filters work great. I even clean and re-use them.
Dave Livesey
2007 Midwest Super Comp Series Champ
S/C 302A is offline   Reply With Quote
