Go Back   CLASS RACER FORUM > Class Racer Forums > Competition
Old 01-24-2009, 08:21 PM   #21
Kevin Grasson
Default Re: Modified questions
Thanks, didn't have my rulebook handy. The w2 would really be the only choice for that combo, and when done right they flow pretty well. I don't do very much small block stuff, but I would imagine that he is running a later casting, 48* (if a 48*block is allowed), small chamber non econo head so he can run the t&d rocker gear and not have the valvetrain stability issues that the 59* would have at the rpm he's probably turning.
Kevin Grasson is offline   Reply With Quote
Old 01-25-2009, 02:18 PM   #22
Freddie
Freddie's Avatar
Liked 3 Times in 2 Posts
Have been looking into this myself lately..
From what I have understood, NHRA allows the 351C style Yates heads as well, they all have a Ford Part # cast in them. I am looking at a 311 Yates heades combo for ours.
NHRA: Comp 2200 - S/C 2201
NMRA 2012 Outlaw 10.5 #10
Freddie is offline   Reply With Quote
Old 01-25-2009, 10:34 PM   #23
RPM5595
RPM5595's Avatar
Liked 32 Times in 14 Posts
I sure hope they allow the Yates heads, cuz thats what I'm building. Curious, why are you building a 311 cube engine? Cant run SS/CS with them and 311 is kinda small for SS/BS is'nt it? Maybe I missed something. Or, maybe you're building a SS/?M with 2 fours? That would be a screamer!
Jay
Jay Roeder
facebook.com/racefuelsales
Former N/SA , Soon to be SS/AS, Renegade Race Fuel dealer
RPM5595 is offline   Reply With Quote
Old 01-27-2009, 11:02 AM   #24
Freddie
Freddie's Avatar
We are actually looking at G/SMA
Old 01-30-2009, 01:27 PM   #25
Ven302
Ven302's Avatar
Liked 34 Times in 7 Posts
The 311 Yates headed piece is a good fit for SS/DM WITH 2 4BL
10.50 x311 3265 less the auto break -163 = 3102 NEED 817ISH HP TO RUN THE RECORD 150MPH
530 FOR THE INDEX
SS/CM
9.50 X311 2954 - 147 2807. 909ISH HP RECORD 158MPH
530 INDEX
WEIGHTS WITH DRIVER INCLUDED
Ven302 is offline   Reply With Quote
Old 02-10-2009, 10:35 AM   #26
randy wilson
Liked 22 Times in 22 Posts
anyone going to the ihra divisional race at thompson ohio? is it a fast track?
don,t have one
Old 07-23-2009, 08:04 PM   #27
Ron E
The N351 short deck motor should be a great CS motor. Another plus with the Ford is a finished 8.2" block won't cost you almost twice as much a 9" block as is the case with GM. What it will take to get the gains on the track is another story, but the 15°W2 (or even the standard 18°) and the 10° N351's just look better for SS/CS than the bowties. Main thing is the pushrod pinch isn't nearly as bad as the chevy. (no external port modifications in the port areas). The port cross section on the Dodge or the Ford can be much more consistent.
But, Mann's may not be impressed with my observations as his stuff is flying. There's always at least one racer who screws up a perfectly good theory.
Ron E is offline   Reply With Quote
Old 07-27-2009, 11:13 AM   #28
BlueOval Ralph
Banned
Find early heads raise the port 1/4 to 3/8 " fill the floor to the short turn. There is enough material in the roof of the casting.
BlueOval Ralph is offline   Reply With Quote
Old 07-27-2009, 03:23 PM   #29
Ron E
Jay
Jay, we've done top-ends for 314 and 315 inch BS motors. So, I guess 311 could fit too.
Ralph, you're right on those 351 iron heads. They also have pretty good bowl thickness as cast. They have great potential for CS. A friend of mine out in Washington state has built them for allky round track racing, and tells me they will flat out make more HP per CFM than a bowtie. Considering they will potentially flow more than a bowtie, that sounds promising.
Old 10-27-2009, 10:11 PM   #30
The A in ARrace
I am also looking into building a ss/cs car and would like to know if you have to adhere to the normal nhra listed runner size of a year/hp combo like standard ss.
Joe Adkins
The A in ARrace is offline   Reply With Quote
