Go Back   CLASS RACER FORUM > Class Racer Forums > Competition Tech
Old 07-17-2009, 10:18 PM   #1
div4rules
Default jr fuel dragster
we are building new car to race in local circuit swjrfa
we can do just about anything to heads but must be iron heads
looking for thoughts on heads to use any thoughts would be greatly appreciated
also must be small block chevy
div4rules is offline   Reply With Quote
Old 08-03-2009, 06:07 PM   #2
Dragsinger
Liked 99 Times in 60 Posts
Default Re: jr fuel dragster
Divn 4 racer,
check your private message
Larry Woodfin
Larry Woodfin 471W
Old 08-03-2009, 09:08 PM   #3
Schenck
Racing Head Service heads are the most popular.
Greg Schenck
Schenck is offline   Reply With Quote
Old 08-18-2009, 08:56 AM   #4
Adger Smith
Liked 880 Times in 311 Posts
Greg,
Arent the popular RHS heads a raised runner? I've been looking at the S/WJR Fuel rules for a customer and it says "no raised runner heads" Should have ask what non raised runner head works best?? There are a lot of brands with various port sizes out there.
Adger Smith (Former SS)
Old 08-19-2009, 01:52 PM   #5
Schenck
Adger, I was assuming that the southwest rules were the same as B/nd.
Greg Schenck
Old 08-19-2009, 07:18 PM   #6
Adger Smith
I'm not up on B/Ndragster class rules. I just looked at the rules for Southwest Jr Fuel Assoc.
http://www.angelfire.com/tx/fuelcarf...lers/main.html
I noticed there were no raised runner heads. I was thiking of the RHS raised runner 23 deg, that is actually a 21 deg, or something ..
- B/JF: 3.50 pounds per cubic inch, 1,350 pound minimum weight. Limited to OEM cast-iron Hemi, 23 degree Chevy (no raised runner) OEM or aftermarket replacement style, OEM Ford or aftermarket replacement style heads. Other makes fall under same category as above. + or - 3 degrees maximum allowance for milling of heads.
Old 09-10-2009, 09:13 AM   #7
ESCOTT427
We're looking for same info, run in SWJFA,Tom Hixson @www.swjfa.com. In use you'll see everything from stock "turbo" 292 castings (us) to Ported $8000 AFR and RHS heads. Lots of good stuff, to run 4.80s ,buy the best you can afford.
We're a full second slower, but learning the car and driver in prep for next season. Welcome to the group!
ESCOTT427 is offline   Reply With Quote
