Old 06-23-2009, 12:37 PM   #1
Rory McNeil
Liked 1,102 Times in 301 Posts
Default Need Ford 8.8 gears
I need a set of 5.13 gears for a Ford 8.8 rearend, new or good used. Thanks. Rory (604) 589-6883
NHRA 6390 STK
M/S 85 Mustang
Old 06-24-2009, 06:26 PM   #2
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Default Re: Need Ford 8.8 gears
Rory,
I had a hard time even finding this one?
http://www.4wheelerssupply.com/catal...ducts_id/71196
Good luck.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 06-24-2009, 06:59 PM   #3
FED 387
Liked 330 Times in 178 Posts
Try Ron;s Machining Service in Michigan $210 each
Old 06-24-2009, 07:57 PM   #4
Earle Holt
Liked 4 Times in 1 Post
Rory =
Jawsgear.com has them for $179. These are the Motive gears that I run. The ring is back-cut so they are alot lighter than other gears I've used.
Earle
Earle Holt 1055 Stock
Earle Holt is offline   Reply With Quote
Old 06-24-2009, 08:48 PM   #5
6031 stock
Rory that is what I run Motive back cut had no problem getting them
Marshall Greenwell K/SA
6031 stock is offline   Reply With Quote
Old 06-25-2009, 01:41 AM   #6
Rory McNeil
Thanks guys, the 5.13`s I was using until I broke the pinion this past weekend also had the back cut ring gear, I bought them from Moser 3 or 4 years ago. I found a set of Yukons locally, so I should be OK, but I will keep Jaws gear in mind and may buy another set of Motives for "next time". Earl, how long were your 5.13`s lasting for, with the stick?
NHRA 6390 STK
M/S 85 Mustang
