The rule states that the stock wrist pin diameter MUST be retained, yet in the case of the LS1 the OE pin diameter is .945", yet all the approved rods have .927 diameter small ends?
And some Fords are allowed Chevrolet aftermarket rods. Just a concession to parts availability I'm sure. Once allowed, even if the correct part becomes available, they usually do not change the legality of already approved parts.
Alan Roehrich 212A G/S |
There are plenty of .945" rods available, but none of them made the list. So the legal rod with it's .927" pin and pin bore supersedes the stock diameter pin requirement?
#4 | |
I'd say you should probably call Wesley Roberson to make sure that you would not have to open the rod up 0.018" to accept a 0.945" pin.
Look on the Rod list, it says this...(Must use OE size pin or larger) for stock, regardles of how it is produced you gotta keep the size on the piston sheet.or larger ...
Bub Whitaker Last edited by Bub Whitaker; 02-13-2009 at 10:08 PM. |
In know from experience, if NHRA provides an aftermarket rod and the pin size is different than OEM, you are allowed the aftermarket size that the rod is built around. This is due to most aftermarket rods being built around a .927" pin and 2.100" large end as most aftermarket rods are built off a SBC blank.
Jeff Lee 7494 D/S '70 AMX |
Liked 89 Times in 19 Posts
Jeff,
In my experience a couple of years ago, we were advised that we had to keep the original pin size as per Bub's post. The motor in question was a 307 Oldsmobile that had an approved 6" Chevy rod but we were told that we had to use the stock pin size (.990 as I recall) in order to be legal. I haven't heard of that rule being rescinded. c |
#8 | |
Banned
If you go to the complete piston and rod list, the LS1 piston has been approved with the .927 pin. Also the piston is approved with 1/16 1/16 3/16 rings, with optional 1.2 1.5 2.0 ? rings. I guess you can't believe anything NHRA tells you, even if its in writing!!
Bruce |
#10 | |
Bub Whitaker |
