Old 02-11-2009, 11:56 AM   #1
mannymen
Liked 13 Times in 7 Posts
Default Flexplate?
Does anyone make an SFI flexplate with a bolt on ring gear? I thought I saw one somewhere, but can't remember where. JW does recert their flexplates, but they have to replace the ring gear to do so for $110 Need another flexplate and don't want to go that route.
thx
N/A
mannymen is offline   Reply With Quote
Old 02-11-2009, 12:51 PM   #2
FED 387
Liked 336 Times in 183 Posts
Exclamation Re: Flexplate?
reactor or CSR
Old 02-11-2009, 04:59 PM   #3
mannymen
Default Re: Flexplate?
Called both and Reactor will recertify their aluminum flexplates and CSR will not. Hard to spend near $300 dollars on the CSR piece to throw it away in 3 years.
N/A
Old 02-11-2009, 05:25 PM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
Gave up using the JW and CSR wheels for the same reason. ..The $50 Jeg's flex plates have actually held up better than the big $ pieces. use em and toss em ......I'm a little leery of the Reactor plate. One ,it does not have any flex to it ,it is a 5/16" piece of 6061. Two, I've repaired a car that was nearly cut in half when the allen cap bolts that hold the ring gear on sheared.......Granted that can happen with a welded unit too, but I've only seen ones with little pieces missing between the welds. .....Tom
Old 02-11-2009, 08:37 PM   #5
Todd
Todd's Avatar
Unhappy Re: Flexplate?
I agree with you on the no flex part, we used one in our bracket car and only got 1/2 a season out of it.It cracked around all of the crankshaft bolts. Allthough the bolt on ring gear stayed attached just fine.It is now expensive wall art.
Todd Melville
Melville Racing
1577 T/STK
1971 Boss 351 Mustang
Todd is offline   Reply With Quote
