First of all, if I am not mistaken I thought it was legal to leave off a button and 2 step in stock, but not a transbrake. Maybe this is just an NHRA rule and not legal in IHRA. At any rate, with some bracket tracks going No Box instead of footrbake and not thinking my car would be suited to a transbrake leave I was thinking about this. If this is something anyone has played with how do you mount the button. I have heard of them being on the footbrake, but can you use just any old button to do it this way since you will be applying quite a bit of pressure to the butto? Or, is it just as easy to let go of the button with your finger and the footbrake at the same time? How much RT can be gained by leaving off a button and a low side pill vs. off just the footbrake?
Liked 5,153 Times in 1,967 Posts
You can't leave off of a button in Stock, unless it's on the brake pedal, as of last year.
Like so: ![]() The switch on the shifter is for low gear only activation of the two step.
Liked 14 Times in 11 Posts
My understanding is for Stock Eliminator you can have a 2 step,
but the button can only be mounted on the brake pedal and it is activated by your foot. Nothing that your hand could control.
Phil Saran Parker, Colorado |
Any special type of button you use for a brake pedal application? Can you say a button on the pedal is helpful with your RT vs. just leaving off the footbrake?
Never though about a micro on the shifter to only activate the low side in first gear only. Good idea. |
#5 | |
I'm pleading to please accept my ignorance here. I'm slowly trying to reacquaint myself after all these years, I'm not familar with a 2 step (or a 3 step for that matter). Is the switch on the brake pedal used simply as a rev limiter, limiting the amount of rpm's that you stall the converter? Also, is the switch on your shifter wired in conjunction with the roll control? This allowing you to control the peak rpm during your burnout. Robert Swartz
Robert Swartz - Swartz & Lane 66 Chevy II Pro 95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock |
#6 | |
Donnie Moore Jr. SS/GA 9401 ![]() |
#7 | |
![]() Robert, The 3 step is commonly used as such: Module 1, used to limit starting line RPM.Usually an adjustable module Module 2 , used for high side over- rev protection Module 3 , used to limit burnout RPM, commonly hooked to the line loc (Not used in car in picture.) The switch on shifter is used to complete the 12V feed from the brake pedal button to the 3 step box for Module 1, in low gear only. That way, it won't activate when braking at the finish line.
"We are lucky we don't get as much Government as we pay for." Will Rogers Last edited by Mark Yacavone; 02-09-2009 at 06:34 PM. |
Is there any R/T difference leaving off of a rev limiter versus just footbraking?
Jacob |
But if it is a No Box track that allows transbrakes they should allow the 2 step as well correct?
#10 | |
