Liked 43 Times in 29 Posts
Looking to purchase an electric winch to mount in an enclosed trailer to pull a 3200 lb. door car. Been looking at 12 and 120 volt units and various horsepower ratings. Not looking to break the bank and the unit will probably get minimal use.
Thanks
Mark Ruset 2048 STK |
Liked 524 Times in 141 Posts
Oh, an electric one. Can't help you with that. Sorry.
Liked 800 Times in 337 Posts
I would think 12 volt would be best, especially if your trailer already has a battery. That way no need to plug in or start the generator.
For light use I would consider the Harbor Freight units. |
Thanks I was thinking along those lines. Just not sure if the 3500 rated one will work for my application and HP rating for the motors, I've see all the way from 1.3 to 1.8 on the horsepower of the motor, also some units have steel cable and some use a fabric type rope. Just want to make a one time purchase.
After twenty years the steel cable on my winch failed. However for many years before that it had strands sticking out that could have been painful it not handled with gloves.
I replaced it with a fabric rope and I like it. |
Liked 54 Times in 27 Posts
since you are just pulling the car, you don't need a 3500 lb winch. 2500 is enough, plenty. If the cable begins to fray, replace it. When winching, have someone follow the car with wheel chocks, just in case it gets loose.
Liked 24 Times in 17 Posts
I have a Harbor Freight 3500 with synthetic line.
Pulls a 3700lb car easily. Use a snatch block on the floor D rings. Winch mounted on the side out of the way, |
Liked 331 Times in 179 Posts
depends on if you are pulling a dead weight or a rolling weight also the angle of the incline---if you use a snatch block and double your line it will pull it very easily because you are doubling the power however your speed decreases. but it should work--- look into it before you make a decision--FED 387
I ended up buying a 5000 lb. Badlands Winch from Harbor Freight. I spoke with a tech guy about the capacity of the winch and was told that the longer the tow cable is extended from the winch the larger the capacity of the winch needs to be. I purchased it on Fathers Day for $170.00 Looks well made and had great on line reviews
Liked 101 Times in 27 Posts
Superwinch.........run the other way........company bought out and out of business......fell for a sale on ebay at 1/2 price ......the switch went out when I needed it most......no replacement parts anywhere what a pain......ended up making one, what next ????
NHRA AND IHRA STOCK ELIMINATOR 2772 |
