Old 04-08-2012, 08:35 AM   #11
HP HUNTER
Liked 372 Times in 129 Posts
Default Re: BBC Iron heads
Originally Posted by 1320racer View Post
I didn't forget anything, you forgot to be truthfull AGAIN in another post whose sole intent is to solicit business.
FYI, that trans sells for $4,000 - $5,000 USED...
http://classracer.com/classforum/sho...light=Coan+XLT
That said, don't know, don't care who your customer is, "what is full weight" and "I think" is meaningless speculation, besides it appears no one in your area has ever seen your car run, no mind back up your claims...
Per Mark Guthrie, a guy that first met HP Hunter aka Mark Jones in 2007, knows him well, and "helped him in his shops for months", "Mark has talked about his "3600 lb. Chevelle" dozens of times. I have never seen him run any of his cars, ever and I am just saying none of the locals have seen it."
Meanwhile, Bob's Chevelle runs good, it should, it's nearly 300 lbs. lighter than my '68 and has nearly 40 more cubes and I've been advising him for over a decade.
Again, nice to see that after 5 years, some have caught up and some have surpassed my former Chevelle's performance as is the case with the car HP Hunter speaks of, even if it took 30+ more cubes, a light weight, low drag transmission in a car that weighs nearly 300 lbs. less and last but not least a -1600' DA to do it!
Just saying.
BTW, the compression ratio of this 496 is at least 10.8 not the 10.7 you stated.
Just keeping it real.
My chevelle that you refer too, weighs 3720, ran 10.10 @ 5320 feet DA with a 27.45 Baro with a 118 grains of water the first full pass down the track with a standard weight trans, just facts. Johns trans is the 3000.00 version that Coan sells,
his car weighs 3615-3630, just facts, the second time John took the redbull out in some + 2000 feet DA with some more tuning the same exact MPH was run, as in the negative 500 feet DA of the afternoon runs a few months ago. And finally, Bob West's chevelle weighs 3680. Just keepin it real, and the facts strait. Ive allways been a big fan of your chevelle, Im really not sure why you have the burning desire to compare my stuff to yours. I think when you look at 40 Coupe, Bob West, John Wilson, and my own chevelle, the performance speaks for its self. BTW, I dont need any more buisness.
Old 04-08-2012, 08:49 AM   #12
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
it's YOU and team clueless that always compare your stuff to my former ride who's best numbers were run 5 years ago and sold nearly 4 years ago.
Old 04-08-2012, 09:01 AM   #13
HP HUNTER
Nice picture!Really no reason to compare, were just simply much faster.
Old 04-08-2012, 09:15 AM   #14
1320racer
1320racer's Avatar
who's "were"?
YOU ain't much faster, in fact slower and again, it's YOU that is trying to prove something, chasing the performance of a car that I sold 4 years ago...
that never was built to run in the 9's, hence no rollcage, though it did, with a restrictor plate having 1 1/4" bores under it's 4150 carb...
it also ran 137 MPH.
meanwhile let me know when you and team cluless run in the 8's, run 150+MPH and 60 foot 1 teens no mind a 1.17.
Old 04-08-2012, 09:24 AM   #15
HP HUNTER
who's "were"?
You ain't much faster and again, it's YOU that is trying to prove something, chasing the performance of a car that I sold 4 years ago...
How about low eights on a ten inch tire @ 3350, maybe you forgot about those two strait championships in Hot street as an engine builder, 10 inch tire, all motor, NA, heads up racing. I was thinking, you should come over to team clueless, we could use a guy to get under there and make those chassis adjustments.
Old 04-08-2012, 09:26 AM   #16
1320racer
1320racer's Avatar
again, YOU ain't done anything and more claims you can't back up.
Save your claims and sales pitches for team clueless. I ain't impressed and could easily out run team clueless's mascot with the same cubes, backed too with a $6,000 trans, at the same weight and in -1600DA air.
Old 04-08-2012, 09:36 AM   #17
HP HUNTER
Come on Ed, you couldnt run any better than a 9.89 @ 134 with a 522 inch aftermarket race gas engine in that chevelle in - 2000 feet air, meanwhile Team Clueless, 9.50s first full pass down the track with a pump gas GM oval port, production blocked 496, Just sayin.
Old 04-08-2012, 09:41 AM   #18
1320racer
1320racer's Avatar
misinformation, half truths and LIES just as all your claims and wilson's posts about his car/combo(s)
Again, I could easily out run team clueless's mascot with the same cubes, backed too with a $6,000 trans, at the same weight and in -1600DA air.
Old 04-08-2012, 09:43 AM   #19
HP HUNTER
Does this mean your not coming over to Team Clueless? LOL
Old 04-08-2012, 09:54 AM   #20
HP HUNTER
You couldnt do it with a 522 inch aftermarket race gas engine, 9.89 @ 134 in negative 2000 feet air, with atleast a whole year of dial time, my pump gas oval port 496 looks pretty darn good to me right now, 9.50s first time out. Just facts........
