Old 11-10-2006, 12:50 AM   #1
NORMAN BARNARD
Liked 2 Times in 2 Posts
Default Don Davis 96 Oldsmobile
Don Davis 1996 oldsmobile cutlass supreme , tig welded , mild steel chassis , nhra certified but has now expired.
roof and quarters are steel, all other body parts are from hairy glass , front clip , hood, scoop, doors, ground effects, trunk, back bumper, and dash
set up for bbc and mid plate
pro stock alum radiator with 1600 cfm fan
rack and pinion steering
msd 7-al3 wired by msd locally here in town
hurst qtr stick with rear exit cable and electric shift
cc-3 control box
throttle stop w/ brackets and hoses all gauges are auto meter liquid filled , oil, water, and fuel
auto meter tachometer w/ memory recall
painless wiring fused overhead control panel
ford 9 inch with 4:56 pro gears and steel spool w/ strange axles, and custom don davis four link and new drive shaft
front shocks are strange struts and the rear are santuff pro mod double adjustable shocks
alumalite wheels front and back
mickey thompson tires front - 24/4.5/15 and the back are 32/16/15s
harwood fuel cell
mallory #270 fuel pump
don ness pro stock style ceramic coated headers with 2 1/4 inch diameter tubes
stroud super gas parachute
fuel pump, water pump, and radiator fan are all on relays to maximize voltage
car weighs 2350 lbs with driver who is 5'11 at 210 lbs, car was set up with a cast iron big block chevrolet and powerglide transmission
also has clutch set up for manual transmission
asking $ 27,000 roller
will trade for a late model fuel injected stocker , firebird or camaro , MUST run 1 second under index
any questions , please email to nbarnard@elp.rr.com
NORMAN BARNARD is offline   Reply With Quote
Search this Thread:
Advanced Search
