Liked 69 Times in 15 Posts
This is the car in my avatar.
Runs B, C, and D/SA, currently running in C/SA @ 3635 lbs. Real 1970 GS big block car with clear title. Comp cam, Trend lifters, T&D roller rockers, ATI damper, Hayes SFI flywheel, Diamond pistons, Total Seal Advanced Profiling ring package, Crower/TA rods, Clevite bearings, TA front cover and oil filter adapter, Canton oil filter and accumulator. Engine spec sheet MSD 7530T ignition box, distributor, and wires Magnafuel Quick Star 300 fuel pump with MP9945 return style regulator. Jason Line Qjet Stainless steel, Headers by Ben (Ben Line) ATI MRP Treemaster converter with Scott McClay TH200, JW UltraBell, Hurst Auto Stick III shifter DTS GM 12 bolt housing with TA girdle. Mark Williams aluminum spool with 3.250 inch carrier bearings and gun drilled axles. 4.30 polished ring and pinion AFCO double adjustable shocks, front and rear AFCO rebuilt and revalved front shocks January, 2024. Wolfe Racecraft anti-roll bar Titanium wheel studs and aluminum lug nuts, front and rear Wilwood disc brakes, front and dual caliper rear Weld AlumiStar wheels, Goodyear slicks-Mickey Thompson front tires 10 point chrome moly roll cage Powermaster starter and alternator 2) XS Power 16 volt batteries and charger-Flaming River battery switches 2) Painless Performance toggle switch panels Griffin aluminum radiator-dual electric fans, Meziere HD electric water pump Tilt column and Grant steering wheel Halotron (clean agent) fire extinguisher RJS five point seat belt harness, certified to June, 2026 RacePak V300 data logger Computech log book Toshiba Satellite lap top computer to use with RacePak and MSD 7530T. On my PC, I have made a Word program telling some history about the car and what has been done to the car. Including brands of parts and part numbers. It is six printed pages long. This is great information and will save guesswork for the next owner. Best 1/4 mile run - Beech Bend NHRA National Open 5/27/23 10.473@125.38 Best 1/8 mile run - Ohio Valley Stock/SS combo 10/26/24 6.527@102.31 I was only able to race this car three times in 2024, because of health reasons. All three times were at Ohio Valley. $50,000 The suspension components are the same as any 68-72 GM A body. Also, uses a GM (Chevrolet) 12 bolt rear end and TH200 transmission. The firing order is 18436572, so valve adjustment would be familiar to most racers, and uses a Quadrajet carb. UPDATE Replaced flywheel with new JW SFI light weight flywheel 93008L on July 2, 2025. Call 270-234-4259, if no answer, please leave a message. 8am-8pm EST PM and texts, OK Thanks,John Last edited by John Osborne; 07-03-2025 at 06:50 AM. Reason: Additions |
Liked 48 Times in 10 Posts
Here are some photos of the car.
