Liked 203 Times in 52 Posts
Does this Burnout guard work and if so how is it to clean up after the weekend?
Thanks in advance https://www.summitracing.com/parts/g...oIhbRfa8FLE_H5
The more people I meet the more I like my dog Kevin |
Liked 474 Times in 83 Posts
One of the best products that we've used over the years has been pledge on the fenders, easy to clean off at the end of the day
Brian Zenzen SS 5404 STK 5401 |
Liked 232 Times in 69 Posts
A guy that raced a pristine show car at our local track years ago told me about using Lucas Oil Slick Mist on the quarter panels. Just spray it on and let it air dry, do not wipe it off. At the end of the day, I take a wet towel and any rubber or dirty water residue wipes right off. I've been doing this for over 5 years now and seems to work great. Hope this helps.
I had heard of Pam spray for pots and pans but it seemed like it my drip off in the heat.
Liked 485 Times in 160 Posts
Old school fix was a thin coating of Vaseline.
Liked 708 Times in 285 Posts
Maybe baby oil. I think that the dirt track guys use it for easy clean up
Liked 108 Times in 29 Posts
Burn out clean up after the weekend?
We use WD40 . Spray a coat on lower qrts and rear bumber ends. Clean up is easy. I also spray the front bumper and grill/hood edge on my town truck before we leave town.. Cuts washing the bugs off to a minimun. Last edited by Demon340; 08-09-2024 at 08:09 PM. |
I took some pledge and Lucas slick mist to work and sprayed it on some metal cabinets we have. The Lucas doesn't drip as much and seems to have more of a build up than the pledge. I am going to try the Lucas next time out. Thanks for the input class racers.
Liked 239 Times in 114 Posts
I use Pledge on my Firebird, but I don't spray alot on , so nothing will drip off. It is relatively cheap, which is a bonus !
Just an update. I applied the Lucas Slick Mist to the frame rails (dog leg) , quarter panels and rear bumper. This worked mint. I also found some mud flaps and fastened them to the car wheel well area with large spring paper clips. This worked great also and didn't have to drill any holes. At the end of the weekend remove mud flaps and wipe everything off. The little rubber left was easily cleaned up.
Thanks Classracer for the opinions,very much appreciated.
