Liked 27 Times in 8 Posts
For ss 904 is there a air/ electric / nuclear/ mind controlled/ shifter that works with a tran brake/ clean neutral valve body
Liked 3,247 Times in 987 Posts
PPP w/ clean neutral and air shifter works great on my 904.
ppp co2 with biondo controler
Liked 114 Times in 29 Posts
M&M shifter w/air will work great also
thanks all
Paul Forte was also working on a clean neutral version, you might call TurboAction if you can?t find a PPP. Brad and his Dad worked tirelessly to keep up with demand, IMO the M&M represents patent infringement. It?s been a while since I?ve talked to Brad but his tech support was awesome in fixing an issue I had with a unit installed by a previous owner.
Liked 503 Times in 131 Posts
I use a ACD controller, co 2 system with my classic turbo action shifter, with clean nuetral, in the dakota, dart has newer style ta shifter same setup, both work great.
Eric Merryfield 1883 STK |
Did Paul Forte modify your TA for clean neutral, surely not just a shifter plate?
Here she is
Its not altered, for the air shift, a spring is altered. I used to run it shifting myself, which was ideal, except for the straight 2-3 was too soft and I could too easily go from 1 to 3. If I had to do it again, I'd likely alter the shift pattern with some sheet metal like some have done to keep that from happening.
Eric
