Old 12-10-2023, 11:48 AM   #1
fred goodwin
fred goodwin's Avatar
Liked 35 Times in 11 Posts
Default what stock combo is worse (or better) 1969 250-6 or 307 v8
So I had a brain storm ! after reading Billy's budget stocker post last summer, it got me thinking, I have a 69 Camaro streetcar 12 bolt, 4 speed, better axles, slap bars drive shaft loop you know the usual hot rod stuff! but it does not have a roll bar ( I don't want one either) and is by no means a race car! if it had a bar it would open many other possibilities.! anyway, what are your thoughts on this plan! I have a complete 307 carb to pan (I've read this motor combo is very under carbed) and I know of a cheap 250 6 cylinder for sale! what are the chances of putting together one of these 2 motors to build an index running combo on the cheap! (like some machine work,a cam ,good valves and a stocker valve job) not looking to run way under the index! I have plenty of chevy v8 transmissions, converters, shifters ,headers, lite weight race wheels and that kind of stuff laying around , I know Billy has run both these combos in his nova and I hope he chimes in! thanks ....................fred
fred goodwin is offline   Reply With Quote
Old 12-10-2023, 12:59 PM   #2
fred goodwin
Default Re: what stock combo is worse 1969 250-6 or 307 v8
to run the index in P @ 3290lbs with the 307 it would have to make a minimum of 270 hp ! is that even possible with a budget built motor?
Old 12-10-2023, 03:32 PM   #3
Doug Hoven
Liked 870 Times in 165 Posts
Billy has never run a 250 inline 6. Billy (and I) have played with the 230 combo (him much longer than me). We discussed the 250 a few times, and sort of figured the 20 extra cubic inches, but the same 1bbl carb really didn’t equate to a better combo. Billy has done the 72 307, which is a little different than a 69 307. The 230 isn’t too bad. I was able to go .50-60 under with good pistons, a good cam, and a good valve job. Converter and transmission are very important too. Good luck with whatever combo you decide!
1189 F/SA
Defunzalo Racing Enterprises
Old 12-10-2023, 04:27 PM   #4
fred goodwin
thanks Doug , i dont have a 6 cylinder yet but i do have the 307 and if i can come close to the index with a basic stocker deal and have something to work with thats fine , what im trying to figure is which one is a better starting point before i buy the 250.
Old 12-10-2023, 06:31 PM   #5
JGarey
JGarey's Avatar
Liked 25 Times in 11 Posts
Id say drop the 307 in and see how close to the index you are with what you have, then decide if it's worth going further with it.
I bracket raced my camaro for several years with a close to stock combo before deciding to put it into stock eliminator.
Good luck....
Or you could sell your car to me, my camaro was the one that I should have kept
James "jim" Garey
Former Texas Motorplex track champion
JGarey is offline   Reply With Quote
Old 12-10-2023, 07:06 PM   #6
fred goodwin
Good luck....
yeah probobly what ill do, see how slow it is and take it from there
Old 12-10-2023, 07:23 PM   #7
rick winchester
Liked 208 Times in 35 Posts
I dont pretend to know half as much about 6 cyl . as Billy but a 230 @140 in Vsa sure looks better to me than a 307 @ 195 in Psa . If I remember right when Billy ran a 307 in his Nova it was rated @168 hp. Just my opinion Rick
Rick Winchester Stk 3277
rick winchester is offline   Reply With Quote
