Liked 225 Times in 30 Posts
1- NEW Pro Trans F front planetary 26/58 2 runs $500
1-NEW Pro Trans # 6 rear planetary 36/70 2runs $500 1-used Pro Trans #6 '' '' '' $300 1-New 904 trans Mopar Perfomance deep pan $50 1 used 904 2,75 1st gear set , this is Mopar not Pro Trans $275 1-New 10'' Pecision Industries 3000 stall street/strip converter, 727 BBM $300 1-rebuilt 727 BBM transmission, deep pan, manual valve body $750 1-New B&M Super Cooler trans cooler $75 1-used ACD air shifter,with air bottle older unit $250 1- used B&M PRO RACHET shifter with cable $250 1New B&M shifter cable 4 ft long $45 1-NEW B&M shifter cable, 5 ft long $50 !-NEW ATI 12.625 long PG input shaft $50 1-NEW TCI 12,875 long input shaft $50 1-used PG to Turbo input shaft $150 1+used PG aluminum pan $50 2-ATI 208,straight cut gear sets, broken pinion gears $50 760-630-9094, no text Last edited by Gregg Luneack; 10-13-2023 at 01:19 PM. |
Liked 2,516 Times in 701 Posts
I will take the Shifter cables.
